Results 21 to 30 of 35
- Jul 2010
- 844
August 9th, 2013 04:16 PM #21
- Jan 2008
- 46
August 9th, 2013 08:16 PM #23
hmmmm I usually shift from D to N while decelerating. Approaching intersection/stoplight.
Also kapag sobrang downward slope yung kalsada, naka neutral ako para malessen yung momentum and mas madali magdecelerate.
and from D to +/- while in slow moving motion (hindi na ko nagpfull stop when shifting)
for 2 years ko na ginagawa yon and wala pa naman weird na naeexperience sa tucson ko.
August 9th, 2013 08:55 PM #24
August 9th, 2013 09:11 PM #25
Which only means that you've been lucky so far.
putting it in N on a downward slope? Wow! Just when you need engine braking! The better drivers (not you obviously) will downshift for even better engine braking. Do not be surprised later if you are on a long downhill road (like going down from baguio or even just tagaytay) and your brakes fade due to overheating, just because you do not know how to properly use your engine. Have you ever wondered why there are signs "USE LOW GEAR" when going down mountain roads?
August 9th, 2013 09:40 PM #26
di ko talaga magets bakit nilalagay ng iba sa P kapag nasa stoplight, kaya PARK ang P kapag pumarada ka lang (equivalent ng nakapasok sa first gear kapag nakapark ka) and keeping it sa D kahit matagal nakastop sa intersection is like leaving your left foot in the clutch and yung kambyo ay nasa 1st gear while waiting to move on a m/t.
August 9th, 2013 09:44 PM #27
August 9th, 2013 10:03 PM #28
- Jul 2010
- 844
August 9th, 2013 10:25 PM #29
August 9th, 2013 10:31 PM #30
Naku naku madaming medyo noob sa automatic. :banghead:
Sent from my GT-I9082
Normal po Yan saken inde bababa need pa re start everybody can share same as my experience so I...
high idle RPM at engine start
