Page 75 of 85 FirstFirst ... 2565717273747576777879 ... LastLast
Results 1,481 to 1,500 of 1692
    Feb 2010
    #1481
    No need to reset just follow procedure in changing batteries like take off negative first then positive then go back install positive first then negative last. Had mine changed to motolite gold 1SMF size last Feb. Had the new batt delivered to our house and installed by the motolite person.
    Jun 2008
    #1482
    Quote Originally Posted by rereyes View Post
    mahina din preno ng tucson. nabangga ako kanina hay....
    Mahina?? Baka may hangin ang fluid sa system. Nag pa-service ka ba ng brake system mo recently? If yes better bleed the system again.
    Ganyan nangyari dati sa akin. Hindi na bleed mabuti ayon napuwit ng tucson ang nakahinto sa traffic light.
    Feb 2010
    #1483
    That also happens to newly installed brake pads, you need to break it in in the first couple of kilometers. In my experience after installing new orig. Hyundai pads it took almost a week of regular driving to get to go back to it's original braking force.
    #1484
    Baka nahuli ka lang ng preno sir
    Hindi naman kasi ako nababangga sa way ng pag-drive ko
    #1485
    Hehehe, sinisi ang preno ha!
    Apr 2011
    #1486
    dati ko pa naman napapansin un. sign din ng kahinaan ng preno un ugong tuwing tatapak sa preno. naka 15k km na tucson maugong parin.
    #1487
    I see!
    May nabasa na rin ako tungkol sa break issue ng Tucson, yung iba nag-a-upgrade na lang na preno, palit break pad, at yung iba naman pinapabayaan na lang & then maybe adjust their driving habit to compensate yung problem.
    #1488
    Yung parang grinding sound sa brakes?
    Naubos na brake pads ko meron parin. Yung pinalit ko wala na.
    Kia Genuine Parts yun pinalit kong brake pads, pang Kia Carens. Pero 4WD kasi yung iX ko. Yung sa 2WD alam ko meron din pero Mobis. Sa Seiring meron, medyo mahal nasa 3.7K.
    Apr 2010
    #1489
    sir pag wala problema after changing battery no need to reset. mine after changing the battery the malfunction indicator lamp appears and there was a change in engine rev. parang kinakapos and after casa scan/reset napaayos. changed to motolite too.
    Quote Originally Posted by NighthawkGT View Post
    Hmm, looks like i myself also is having problems with the battery.
    Hindi na siya 1 click start ngyun. It appears mahina na yung charge holding capacity nito.
    Mukang yung oem brand na from korea is not tropicalized, like the ones na pwedeng mabili locally, like motolite.
    Mine is just 1.5yrs lang. Normally yung mga motolite, 3 yrs ang tinatagal sa iba naming mga kotse.
    So question is, would i have to go to the process of going to a casa for a reset after changing batteries?
    Apr 2011
    #1490
    Starex Gold, wag ka sana sir malagay sa nangyari sakin, before you start comparing driving styles.
    Apr 2011
    #1491
    Noel Salisipan, same to you sir.
    #1492
    2nd batch pa yung sa akin sir. Jan 2010 kaya may mga issues pa. been to Hyundai shaw last week, ok na ulit. brake light switch and hood latch cable were replaced at no cost to me, all under warranty. that's what i like with my dealer, good after sales. hay sana wala nang problema pa ulit.
    Jun 2012
    #1493
    ano need gawin? maingay blower ng aircon ko, may rrrrrrrrr na sound. sumasabay sa ikot ng blower. may naka encounter na ba ng ganito? 2 and a half na car ko. thanks.
    Jun 2007
    #1494
    Quote Originally Posted by autokiko View Post
    sana nga sir, abala rin kasi. mabilis ba ang waiting time sa H. Shaw for them to replace mga parts w/ warranty?
    #1495
    availability ang problema kaya tumatagal pero kung meron palit agad.
  16. #1496
    Medyo no brainer question, yung battery ba ng tucson ix may battery clamp?
    Hindi ko mtanggal e hehe.
    #1497
    nasa harap ng battery sir, sa may base. silipin mo lang using a flashlight.
  18. #1498
    Ok found it. Specific yung bracket niya for the rocket brand na battery.
    I bought a motolite gold battery instead, problem is the old bracket will not fit.
    Nag custom made nalang ako ng bracket, so far so good.
    No check engine warning light or any error code naman na lumabas after installing the new battery
    Oct 2007
    #1499
    ano brand maganda bilin na front break pads . un oem made by mobis or kia un brand mga sir.
    Mar 2012
    #1500
    San po ba magandang tumingin at bumili ng 2012 Tucson mods?
Issues sa Tucson 2010
