Results 7,011 to 7,020 of 7661
October 1st, 2013 04:16 PM #7011
My usual gas in the past is petron xcs...7km/l...now on my 2nd fuel up using unioil quantum...8km/l...both city drive...Tried using shell racing alternate with petron xcs and talagang mataas consumption ko sa shell...try it yourself...and know what's best for you based on experience....
- Aug 2012
- 138
October 2nd, 2013 12:03 AM #7012Wow not bad 8km/l city... right now im averaging 8.5 km/l mixed city n hiway... odo is at 1300km... usually does it get better pa aftr break in? Thanks!
October 2nd, 2013 09:58 AM #7013
^^^Yes, gaganda pa yan basta proper breakin...dapat habang lumalayo mileage, mas gumaganda consumption...
- Aug 2012
- 138
October 2nd, 2013 02:21 PM #7014Thanks Sir, what do you mean by proper break in? kasi mejo old school pa ata alam ko... before people used to say dont run over 100km/hr for the first few thousand km? Not sure na if thats still applicable? what do you recomend? thanks a lot!
October 2nd, 2013 02:29 PM #7015
Although new vehicles nowadays don't need break-in, i still practice yung sinabi mo na not more that 100km/h for the first few kilometers...after nun hataw na! Seriously, maganda parin na breakin sa highway na gamit lahat ang gears and not staying in one spead...para mabatak....pag city drive kasi, madalang ka umabot sa 5th to 6th gear...
- Aug 2012
- 138
October 2nd, 2013 02:59 PM #7016Thanks Sir! interesting... ako kc mejo relax driving lang tlga ako and di ako humahataw... so ang fear ko is ung nabababad sa gear for extend periods... will try to mix it up, although conscious effort talaga on my end since di ako ganon mag drive... haha!
after my first 1000km PMS, the people sa casa filled up my tires up to 37, just found out nung nag pahangin ako again... is this ok? or should i stick to 33 lang? Thanks!
October 2nd, 2013 03:04 PM #7017
Mataas yung 37...you feel matagtag/matalbog? Recommended is 33 tlga...Depende rin yan sa preference mo...nagtry kasi ako mag 35, natitigasan nko sa ride...kaya back to 33...
October 2nd, 2013 05:58 PM #7018
- Aug 2012
- 138
October 2nd, 2013 09:32 PM #7019actually di ko sha mashado napansin an tumalbog sobra... but i did notice na lumambot manibela ko after the PMS... actually baka safer na nga sa 33...
regrding FC, the display says 10.6l/100km which not bad... but i dont think consistent sha sa pag ubos ng gas ko... so far kc ive been gassing up 1k lang basta nag one bar na gas ko pero pag compute ko distance travelled vs the gas i put mas mababa dun... aftr maubos ung tank ko now mag full tank method nako using unioil euro 4 cguro...
October 3rd, 2013 09:08 AM #7020
high idle RPM at engine start
