^ Buhay ka pa pala Eric hahaha
Yung Sportage pinalitan na spark plugs nung 30,000km PMS, regular spark plugs lang ulit pinapalit ko. NGK yun nilagay. 2.0 Theta II engine.
Naginquire ako recently for an oem sparkplug sa seiring...200 per pc...medyo mahal sa 100 plus ni fronte at goodgear....di hamak na mas mahal sa kasa at 2000 plus set!![]()
good pm mga sir. gusto ko sana magpalagay ng turbo timer sa tucson crdi ko, kaso im having 2nd thoughts kasi kelangan daw nila isplice ang certain wires para makabit yun.. will that void my warranty? if so, nagkakabit ba ng turbo timer ang casa? TIA.
Hi Guys, need advice regarding Tucson Theta... Whats the best fuel for it? Ive tried using Caltex silver and gold and im thinking of changing to Unioil Euro 4... is this the best option? or shell nalang? THanks!
My usual gas in the past is petron xcs...7km/l...now on my 2nd fuel up using unioil quantum...8km/l...both city drive...Tried using shell racing alternate with petron xcs and talagang mataas consumption ko sa shell...try it yourself...and know what's best for you based on experience....
Wow not bad 8km/l city... right now im averaging 8.5 km/l mixed city n hiway... odo is at 1300km... usually does it get better pa aftr break in? Thanks!
^^^Yes, gaganda pa yan basta proper breakin...dapat habang lumalayo mileage, mas gumaganda consumption...
Thanks Sir, what do you mean by proper break in? kasi mejo old school pa ata alam ko... before people used to say dont run over 100km/hr for the first few thousand km? Not sure na if thats still applicable? what do you recomend? thanks a lot!
Although new vehicles nowadays don't need break-in, i still practice yung sinabi mo na not more that 100km/h for the first few kilometers...after nun hataw na!Seriously, maganda parin na breakin sa highway na gamit lahat ang gears and not staying in one spead...para mabatak....pag city drive kasi, madalang ka umabot sa 5th to 6th gear...
Thanks Sir! interesting... ako kc mejo relax driving lang tlga ako and di ako humahataw... so ang fear ko is ung nabababad sa gear for extend periods... will try to mix it up, although conscious effort talaga on my end since di ako ganon mag drive... haha!
after my first 1000km PMS, the people sa casa filled up my tires up to 37, just found out nung nag pahangin ako again... is this ok? or should i stick to 33 lang? Thanks!
Mataas yung 37...you feel matagtag/matalbog? Recommended is 33 tlga...Depende rin yan sa preference mo...nagtry kasi ako mag 35, natitigasan nko sa ride...kaya back to 33...
actually di ko sha mashado napansin an tumalbog sobra... but i did notice na lumambot manibela ko after the PMS... actually baka safer na nga sa 33...
regrding FC, the display says 10.6l/100km which not bad... but i dont think consistent sha sa pag ubos ng gas ko... so far kc ive been gassing up 1k lang basta nag one bar na gas ko pero pag compute ko distance travelled vs the gas i put mas mababa dun... aftr maubos ung tank ko now mag full tank method nako using unioil euro 4 cguro...
