Page 66 of 85 FirstFirst ... 165662636465666768697076 ... LastLast
Results 1,301 to 1,320 of 1696
    20w30 and 20w40 15w30? saan nabibili yan?
    Mar 2015
    #1302
    Any auto supply parts store,all gasoline stations,ace hardware. Iba ibang brand lang sir pero yun grade lang tignan nyo pareho lang po.
    I mostly use shell brand sir. Although i also have used petron,caltex,mobile,castrol and top one on some occasions. Ok naman lahat. For our old car yun 15w/30 pag medyo budget yun 20w/40 sa newer car po 10w/30 or 40 grade po.
    Feb 2014
    #1303
    Share ko lang dito sa thread na to yung estimate na bigay sa akin ng kasa for my Accent HB 1.6L
    Wala ako masyadong alam about maintenance pero tingin ko medyo taga talaga sila sa pinapagawa.
    Already asked, and got some advice from fellow tsikoteers and friends sa mga dapat alisin. Ito draft ng balak ko pa check/replace with materials:
    Oil Filter - 612.90
    Air Filter A/C - 1370 (Pinag iisipan ko alisin to. Parang pinalitan nila ung A/C filter noong 10k kasi nasa akin pa yung luma).
    Air Filter Eng - 776
    Fuel Filter - 2524
    Water Sedimentor- 2296
    Engine Flush - 580 (Okay lang po ba later na lang ito? Or talagang kailangan na for CRDI engines?)
    Injector Cleaner - 580
    Silicon Spray - 199 (Hindi naman nila uubusin to noh?)
    HFT Coolant - 319
    HFT Brake Cleaner - 275
    HGMO Engine Oil 6L Semi - 2058
    Misc - 925 (May hokus pokuks talaga dito. Sabi nila para sa mga one time use materials ito.)
    Total: 12514.00
    Any thoughts kung pwede na siya for a 20k maintenance? Thanks!
    #1304
    Quote Originally Posted by foxcloud View Post
    Oil Filter - 612.90
    Fuel Filter - 2524
    HFT Coolant - 319
    Total: 12514.00
    tuwang-tuwa sayo dealer na yan
    engine flush patanggal mo na hindi naman nila ginagawa yan pag walang nakatingin sa kanila.
    canvass ka muna hindi pare-pareho ang presyo ng mga Hyundai dealer.
    Oil Filter - 612.90
    Fuel Filter - 2524
    HFT Coolant - 319
    Total: 12514.00
    Apr 2012
    #1305
    Seriously, what's up with HARI na may anti perforation na warranty pa sila at hiwalay na booklet pa?
    40k
    Just had my oil change. Found Castrol Edge FTT. Better (slow)acceleration. 500/liter.
    oil filter 400
    Underchasis tightening and I looked and I'm amazed at how clean it was. Shocks have no leaks.
    Cabin filter and air filter cleaned.
    Feb 2014
    #1307
    Salamat sa info. Sayang wala akong oras mag canvass. Dapat ata may kilala na taga-loob para mas okay ang service.
    Oct 2014
    #1308
    Hello klangan na bang ireplace spark plug 10k kms tucson ? Nirerecommend kasi sakin ng advisor pero pinacancel ko sana di ako nagkamali. Ok na ba yung 7600 pesos for 10k pms? Yun ang bigay sakin. Quezon ave nga pala yu g casa ty
    Apr 2015
    #1309
    Guys hingi lng ako ng suggestions. Naglagay ako ng isang 12inch subwoofer s koche ko, mlkas sya bumayo tska mgnda tunog nya ksi sealed ung baffle ko. Ngaun, may mga nginig or garalgal na tumutunog s trunk or back seat pg mlkas n ung sound. Ano kya dpt gawin or ilagay? Hyundai accent 2014 sedan low end ung koche ko. Thanks!
    Quote Originally Posted by cmacgm View Post
    sparkplugs at 10k? bullshit.
    Dont be fooled by this SA. First reason is that its not even scheduled at 10k. And its inspect and replace. Not replace because SA tells you so. Join the service personel who will remove and inspect the spark plug. Im for sure it will be like brand new.
    Feb 2014
    #1311
    Just found this. Hyundai USA recommended maintenance schedule with details. Pwede siguro ito gawing guide.
    https://www.hyundaiusa.com/maintenance-schedule/
    Sa susunod parang gusto ko bantayan yung work na gingawa nila. Inspect muna bago replace.
    not even 10days, 45k maintenance na.
    1. brake maintenance: rear pads worn out cost 2800php. not satisfied with tech response. ill get another tech for brake maintenance. (keeping the old brake pads for reference). mushy feel now but strong stopping power. ill need to brake-it in(pun-intended)
    2.tire rotation as per my instruction. they missed this. front left and right were worn out more but evenly. noisy ride now lol. I may need wheel balancing.
    3. atf change 4lit for 2400php. opted for this. SA ask 45k or 65k. of course I want to keep this car extra clean. atf drain looks reddish. process is not dialysis. they drain fill and bleed/level. they bleed/level by running at creep while car is lifted. upshift and downshift feels smoother.
    4. engine oil drain looks amber'ish. quite happy with fully synth oil.
    5. Sparkplugs are scheduled at 60k. I wanted to see them. iridium plugs. still good.
    6. Engine bay spray with high pressure water then dried off with pressurized air. then some antirust spray. not needed too bad I didnt catch it. its only 240php though.
    7. Cabin filter cleaned. not even replaced. im not complaining.
    8. injector cleaning as per my request. 3000php 15minutes. fuel line replace with tank with some cleaner. is this the normal practice? nasty exhaust fumes.
    9. air filter cleaned. I insisted on a new one. 600php. engine feels new.
    *glad they allow me to inspect the car with the tech. and take pictures too hahaha(shutter sound muted)
    #1313
    Mukhang balak pang singilin ka for spark plug tapos di talaga papalitan.
    Oct 2011
    #1314
    Mga Bossing, meron ako PMS voucher 15k (labor/materials) worth 6,000 sa casa >> benta ko 3k na lang. 20k (labor/materials) worth 12,000 sa casa >> benta ko 9k na lang. Text me if interested...09175843144. Thanks.
    Just had my 50k pms. Minor pms plus oil change. I requested for underbody nuts and bolts retightening. Thank goodness my SA was back.
    Doing 140kph sweeping turns are quite smoother now.
    Vehicle is now at 51200 kms. Prepping for 55k major pms lol.
    #1316
    55K is coming fast and looking at not having it done sa casa. Di ko naman na nasusulit warranty. Gina-grasahan lang lagi ang piyesa pag may tumutunog tapos after 2 weeks lagatok ulit hanggang sa nauwi na lang na sa labas ko rin pinagawa. At the expense of 3x the maintenance price for the hope na ma-cover ng warranty yung defect na di rin naman tama ang pag-address regardless kahit saang casa ko pa dalhin, might as well take my business elsewhere.
    Any recommendation sa Paranaque / Makati area na gas / service station na maalam na mag-service ng Hyundai vehicles? Accent RB na gas nga pala 'to. Ideally may matatambayan habang nag-aantay para makatrabaho pa. TIA!
    Quote Originally Posted by batang_raon14 View Post
    For accent owners: Hyundai Accent owners manuals, user guides, repair, service manuals
    all the info you need for servicing your vehicle. You can print and show to your favorite mechanic para mabilis gawa.
    For elantra owners: hemanual.org
    #1318
    Uy, ayos 'to! Thanks bro! So for 55K, I assume ito yung kailangan:
    30,000 miles (48,000 km) or 24 months
    ❑ Rotate tires
    ❑ Inspect battery condition
    ❑ Inspect vacuum hose
    ❑ Inspect air conditioning refrigerant
    ❑ Inspect brake hoses and lines
    ❑ Inspect drive shafts and boots
    ❑ Inspect exhaust pipe and muffler
    ❑ Inspect front brake disc/pads, calipers
    ❑ Inspect rear brake disc/pads (if equipped)
    ❑ Inspect rear brake drums/linings (if equipped)
    ❑ Inspect steering gear box, linkage & boots/lower arm ball joint, upper arm ball joint
    ❑ Inspect suspension mounting bolts
    ❑ Inspect brake/clutch (if equipped) fluid
    ❑ Inspect fuel filter *2
    ❑ Inspect fuel lines, fuel hoses and connections
    ❑ Inspect fuel tank air filter (if equipped) *2
    ❑ Inspect parking brake
    ❑ Inspect vapor hose and fuel filler cap
    ❑ Replace climate control air filter (for evaporator and blower unit)
    ❑ Replace air cleaner filter
    ❑ Replace engine oil and filter (30,000 miles (48,000 km) or 48 months)
    ❑ Add fuel additive *1 (30,000 miles (48,000 km) or 48 months)
    I would suggest following severe usage maintenance of
    every 7500kms for the oil change fully synthetic oil. I would do brake inspection every 7500km also.
    For the mechanical...its really up to you. Casa or outside. Meron naman documents. There are two versions the long(every 15k or 10k depend sa location) and the short(every 7500 or 5000).
    If you have pending underchasis issues. Gawin na immediately yun mechanical tightening. mainly, the front and rear suspension and the steering asembly.
    Hyundai Accent: Maintenance under severe usage conditions - Scheduled maintenance service - Maintenance - Hyundai Accent 2010-2015 Owners Manual
    Jun 2015
    #1320
    Good day guys. Newbie here. Ill have my 1st PMS on Saturday. Sa Hyundai North Edsa ko sya balak dalhin. Anything special that I need to do beforehand? Some preparations perhaps?
Hyundai PMS
