Results 4,781 to 4,790 of 4790
August 19th, 2021 04:10 PM #4781
1.6 crdi vs 1.6 NA gas, I think the crdi will take it in a long sprint. Torque sweet spot of the crdi is around 1,800 to 2,500 rpm & if you try to push it to 3k, it fades. But if you can get it quickly to 6th, it will push on even beyond 3k. I think it matches a 1.8.
- Jan 2008
- 4,726
August 19th, 2021 04:46 PM #4782correct sir... kaya pag crdi lalo na kia/hyundai MT, kung arangkada, shift agad sa 2nd gear, dun mo biritin up to 3k rpm then shift agad..
kasi nga malakas torque.. unlike sa gas engine na sa horse powah naman bumabawi..
kung long distance fast run, lamang gas engine.. pero kung stop go traffic at hauling, lamang naman diesel
August 19th, 2021 07:10 PM #4783
Accent CRDI vs Civic 1.8L - i’d take the Civic anytime. The Civic is more refined , lighter, amd looks much better. Given enough open road, the Civic 1.8L can go over 200kmh.
Our Jetta 1.6L TDI may not have the output of the Accent CRDI but it will do for a daily driver. The Jetta is a heavy car for its size. I have test-driven the Jetta 2.0L TDI and it was much better in terms of performance.
- Mar 2014
- 2,127
August 19th, 2021 07:27 PM #4784
August 19th, 2021 09:26 PM #4785
May 2014 Hatchback at 2015 sedan kami, 90k at 70k kms, respectively. Both diesel.
Major issue, wala. Minor issue, wala din. Stress free ownership para sa amin.
But, getting a pre owned is a different thing from a first hand owner who knew the history of the car. Our hatchback is only driven by my sister and me, the sedan, my brother and me. Daily driven before but now, part of the garage princesses na din, usually used once a week na lang.
August 19th, 2021 09:34 PM #4786
August 19th, 2021 10:35 PM #4787
August 19th, 2021 10:53 PM #4788
October 13th, 2021 11:06 PM #4789
Pubert, I can’t reply to your mail. It always says my inbox is full but yours is the only message there.
As to your query, the Voltronic site will know better. I put it every 10k but what they say, to put it prior to an an o/c makes sense. Will try it next time.
- May 2006
- 1,668
October 14th, 2021 01:42 AM #4790
high idle RPM at engine start
