Results 4,281 to 4,290 of 4793
- Feb 2010
- 127
May 1st, 2016 03:07 AM #4281
- Jan 2008
- 130
May 1st, 2016 07:59 PM #4282
- Oct 2009
- 41
May 4th, 2016 10:29 AM #4283Hi guys, ung accent crdi ko na sedan mg 30k na. Base dun sa nakita ko sa parang guide ng maintenance ang dapat na mga gawin ko is replace na ung mga gear oil ng front at rear axle at gear oil ng manual transmission. is this correct? Also kaylangan pb mg pa tappet adjustment ng crdi? if yes tuwing kaylan advisable? also ung fuel filter tama ba na every 40k kms? . Mabilis tumaas mileage ng sakin dahil pinang ggrab car kasi namin. Thank you.
May 4th, 2016 12:21 PM #4284
mga sir ano po posibleng prob kapag di na ganun ka smooth ang apak ko esp during 2nd and 3rd gear? parang bitin ang throttling nya. sinubukan ko i off ang active ECO ganun pa rin. DCT po gamit ko
Sent from my MI 3W using Tapatalk
May 4th, 2016 12:42 PM #4285
DCT ba kamo? Medyo mayrun gear hunting from 2nd gear to 3rd gear? Common yan sa mga DCT or DSG tranny. Wag mo i-drive na parang bini-baby mo yung gas/throttle. Drive it like a manual with a steady but firm press to the throttle.
DCT is not like the normal AT tranny. Dami comments about the Fiesta having a jerky tranny on low crawling speeds kasi medyo dina-drive na parang AT tranny kaya lagi gear hunting in low gears. Once you get past 3rd gear, DCT will be quick to shift up to the highest gear.
For the mean time, observe how the car responds within different driving conditions. Once you get a feel of how DCT behaves, it will be easy from there on. Take note that modern DCT trannies are programmed to adjust how the owner drives the car.
May 4th, 2016 01:37 PM #4286
May 4th, 2016 01:43 PM #4287
sir jay2 30k pms for accent CRDi change oil lang and at most air filter ng engine. Fuel filter, coolant, cabin air filter should be changed every 20k kms. Yung gear oil and brake fluid, every 40k. Wala pong rear axle ang crdi since front drive lang siya. Hope this helps!
- Oct 2009
- 41
May 4th, 2016 02:55 PM #4288
- May 2016
- 2
May 4th, 2016 05:43 PM #4289Mga boss pano ba maalagaan ang turbo ng accent a/t 7dct crdi ko? Sabi nila pag galing sa long drive,kailangang icool down daw muna ng at least 3mins bago patayin ang engine.tama po ba yun?
May 4th, 2016 06:35 PM #4290
It is good practice with turbo cars (diesel or gas) to have them go thru proper warm-up and cool-down procedures. You don't want that turbocharger to breakdown.
In the morning or when the car was left turned off for a long time (8 hours or so), let the car reach its idle rpm speed before speeding away. It takes about a minute or two for the engine and turbo to warm up.
After a long drive, let the car idle for around 2 minutes or so in order for the turbocharger to cool down. You would know when to turn it off as you can hear the radiator and intercooler ease up on its activity and the engine reaches it idle state. Shutting down the engine right away will force the turbo into a rapid cool down process and may lead to issues later on. In some turbo cars, the radiator and intercooler will continue its cooling cycle (even when the car is turned off) until it reaches its idle temperature.
Adding 2-3 minutes in your travel time is not that much knowing it will keep your turbocharger free of issues later on.
Getting a toyota would be ideal mostly for those looking for practicality or one who will use it...
China cars
