Page 236 of 240 FirstFirst ... 136186226232233234235236237238239240 LastLast
Results 4,701 to 4,720 of 4793
    Quote Originally Posted by Ser Chief View Post
    Tanong lang guys, yung natipid niyo ba sa diesel, nabawi rin sa parts, repairs and maintenance?
    any car with 95000kms will have parts to be replaced. tires, suspension. brakes. atbp
    Aug 2013
    #4702
    I understand that, sir. What I meant was, if the total cost would have been the same, had they opted for a gas version of the Accent over the Diesel.
    parts arent expensive..
    Apr 2018
    #4704
    Got a 2015 accent crdi AT last nov (50,000km). Ngaun na 55k km, ito mga ngastos so far sa maintenance:
    - brake cleaning
    - tie rod & stab links replaced
    - front wheel bearings replaced
    - new tires
    - regular oil change for 55k km w oil filter
    So far mga 40K pesos sa services & maintenance, but I guess ok lang for a 3-4 year old car. Ave ako ng 13km/l (masinag-makati).
    Sa diesel vs gas topic, oil change lng ata difference which in a span of 5k km, I think naoffset ng 8-10 pesos diff ng diesel and gas.
    5,000km / (13km/l) = 384.6 Liters diesel consumption
    assume 9 peso difference (gas vs diesel) per liter
    Peso diff using diesel = (384.6 Liters diesel consumption) * 9 = 3,461 pesos (pang oil change haha)
    Sa hatak, di ko pa naexperience yung gas cvt, but I like the low rpm torque of the crdi's dct.
    Sa highway fuel efficiency, masaya ako sa crdi 4.5L per 100km.
    #4705
    That doesn't take into consideration the difference in fuel economy between the gas and the diesel models.
    On fuelly data submitted by actual Accent owners show they mostly average 32mpg with the 1.6li gas model, while the diesel drivers get 41mpg. Applying the same ratio to your own fuel consumption a gas powered car would have used 469.3li to cover the same 5000km. That's about 84li unaccounted for, which assuming P50/li is another P4,200 on top of the P3,461 you calculated for a total of P7,661 savings every oil change.
    #4706
    Quote Originally Posted by constantzero View Post
    - brake cleaning
    - new tires
    Ako naman may 2014 Accent CRDI with 165,000 kms clocked in. Mga napalitan ko na ay Clutch,fuel filter 2x, brake pads once, tires (fourth set na), EGR cleaning. Others ay routine maintenance. May konting lagitik sa suspension pag asa humps, pero aside from that, OK pa ride. Kaya di talaga ako naniniwala na ang Korean cars bulok.
    Jan 2019
    #4707
    Hello guys
    Ano prefer or ma-suggest niyo na mags para sa hatch natin? 16s or 17s?
    Thanks!
    May 2019
    #4708
    mukhang magiging hit nanaman ito ng hyundai pag ang presyo around 800-850K
    paktay market ng ibang HB nito
    Apr 2011
    #4709
    Quote Originally Posted by kelxcruz View Post
    Hello guys
    Thanks!
    get the OEM 16s sir. Saktong sakto
    Mar 2018
    #4710
    Ako naman may 2014 Accent CRDI with 165,000 kms clocked in. Mga napalitan ko na ay Clutch...
    buong clutch assembly ba, boss? at ba't napalitan? palitin lang talaga o may napansin kang trouble?
    #4711
    Quote Originally Posted by maxq View Post
    Matigas na kasi. Palitin na.
    May 2013
    #4712
    Saan shop sir okay magpa labor ng Clutch replacement? Thank you.
    Sent from my SM-G930F using Tapatalk
    Jul 2016
    #4713
    Mga sir,
    Normal ba yung pag cold start may parang umaagos na tubig sa likod ng dashboard.
    2019 model 89kms mileage ng unit ko.
    Salamat po.
    #4714
    Quote Originally Posted by Napakabilis View Post
    Mga sir,
    Salamat po.
    2014 hatch, 165k kms. Agos talaga or tunog agos lang?
    #4715
    Mga sir,
    Salamat po.
    this is something new to me.
    hard to say, but...
    my wild guess is, that's the sound of the aircon coolant, being pushed thru the tubings.
    if your aircon automatically turns on when starting the engine, turn it off first.
    Jul 2016
    #4716
    Tunog sir. Pero parang may umaagos talaga.
    hard to say, but...
    Same same sir.
    Sinubukan ko start ng patay ang AC meron pa din.
    Aug 2013
    #4717
    Mga sir,
    Salamat po.
    may heater ba accent?
    try mo start sasakyan tapos wag mo muna ON yung AC, kung nawala yung parang agos na tunog, ibig sabihin, AC compressor yun, nag engage.
    normal yun kapag ganun.
    #4718
    Same same sir.
    Baka yung fuel filter
    Jul 2019
    #4719
    Hello po.
    I just bought Hyundai Accent Hatchback 2015 MT. 27kms.
    Ano po recommended na PMS? Kakachange-oil lang niya ngayon before ko mabili sabi nung delear. And any recommendations na shop na master sa Accent Hatchback?
    Aug 2019
    #4720
    Balak ko po mag upgrade from Altis 2004 within the next few months, any thoughts po regarding the Hyundai Hatch 1.6 CRDi GL 7A/T-DCT (Dsl)?
    May mga common issues that I should be aware of po ba yung specific model or si hatch in general?
    Nagbabackread po ako ngayon for more information, pero naisipan ko na lang din mag post. First time kasi namin mag Hyundai buong family and yung family mechanic namin hindi masyadong familiar sa mga sasakyan nila.
Hyundai ACCENT Hatch CRDI 1.6
