Results 31 to 40 of 40
May 18th, 2012 11:49 AM #31
May 18th, 2012 02:14 PM #32
A stuck pedal assembly or trapped pedal is always the most likely scenario in these situations, if there's a physical (non-driver) cause. If you hear them trying to unstick the pedal, that's it.
The question here is whether those are cable-throttle cars or electronic throttle ones. If it's cable throttle... then it's possible the cable got stuck. If it's electronic, no. The answer will lie elsewhere... either with the mat or with the actual throttle assembly sticking.
May 18th, 2012 03:01 PM #33
I think there's one apparent description missing in most SUA incidents. In that, the throttle wasn't stuck at 1/4 or even 1/2. From the roar of the engines, they seemed to have been 'set' to WOT, whether accidentally or uncommanded. No driver in their right mind would go WOT in most of the circumstances in the videos above (ie. turning right at a tight corner, at a traffic light but behind another car, etc.)
Even while driving on the highway, unless you're actually doing spirited driving, most drivers are in the habit of feathering the gas pedal. So if it went from that to WOT without the driver commanding it, it could be the throttle servo, ECU, or the throttle position sensor (either on the pedal or throttle assembly).
Now, an epileptic driver is another thing.
- May 2008
- 230
May 18th, 2012 03:19 PM #34Yep, with a clutch pedal at least you have control as to how the power is transferred to the wheels. Makes me wonder if the manufacturers could develop a clutch assembly similar to the drive-by-wire system of modern accelerator pedals that could work in conjuction with an automatic transmission para we can have a truly manual/automatic transmission. Sarap mangarap!
- Jul 2008
- 754
May 18th, 2012 04:02 PM #35Feeling ko fake yan. I doubt mag full throttle yun sudden acceleration. And besides, bilis lang naman solution dyan, the letter N.
May 18th, 2012 08:19 PM #36
May 19th, 2012 01:12 PM #37
*Press hard on break*
*Press hard on gas*
Uhh.... what seems to be the problem here?
- Jul 2011
- 584
May 24th, 2012 10:05 PM #38im digging if there's a video of CCTV on the net with this news 4 teens killed in Ayala Alabang car crash | ABS-CBN News
and it led me to this thread.
maybe it is really time as this article says Is it time for a car black box? | Inquirer Business
May 25th, 2012 10:21 AM #40
before this accident, may news na rin sa yahoo na may gagawing batas sa US na mandatory na ang car black box. hindi ko lang matandaan kung aling state. nabasa ko rin na ngayon pa lang pinoprotestahan na because of, as usual, privacy issues..
high idle RPM at engine start
