Results 1 to 5 of 5
- Mar 2012
- 2
March 9th, 2012 12:19 PM #1Hi Guys,
Need help and some piece of advice. I think my '96 hyundai elantra is having a radiator leak. for the past 2 days, i have to put in water in the radiator after every use of the car. Its not a problem for me as long as hindi naman tumtitirk ung auto.
Here's the thing, I have an appointment to batangas tomorrow morning for which i have to use my car. Please advice if its safe for my car in this condition to drive that long. Kung sa tingin nyo po kaya naman, pls give me tips on precautionary measures to make sure na hindi titirik ung auto. I'll have my wife and 1 yr old kid with me tomorrow kasi, malaking hassle kung titirik ung auto.
Thanks so much. sana po may mgreply as soon as possible.
March 9th, 2012 12:32 PM #2
troublesome yan sir, better fix the problem before traveling that far. kasama mo pa naman family mo, safety first sir ang i-priority mo. check mo sir kung san yung leak nangagaling, kung sa hoses madali lang yan, pero kung radiator mismo kailangan mo ipa baba yan isabay mo na din overhaul para isang abala na lang. kung wala ka naman nakikita na actaul leak pero mnagbabawas ng tubig pwedeng clog na yung radiator at nag eevaporate yung coolant mo. check mo din yung takip ng radiator, pag may build up ng langis yung tip nya may tagas yung head gasket ng engine mo...mas malaki trabaho yun...
- Mar 2012
- 2
March 9th, 2012 01:02 PM #3na overhaul na kc ung radiator last november. pina welding lng ung mga tagas. pero ngaun may sumisirit uli tubig dun mismo sa pinag weldingan. don't have enough time para ipababa ulit. kelangan ko tlga dalhin ung auto bukas. im coming from marikina going to tanauan batangas. im thinking to stop over 3 - 4 times to check on the radiator and water level to make sure it won't overheat. ok na kaya un just to get over tomorrow's ride?
- Jun 2010
- 466
March 9th, 2012 01:25 PM #4i'd advise against bringing it that far. di mo rin masabi baka lumaki yung tagas in the middle of your trip at maubusan ka ng tubig. remember umiikot yung tubig inside your car's cooling system when you drive it. there's pressure build up, especially when the water gets hot. so malaki ang chance na lumala yung leak the longer you use the car in that condition. kahit na mag stop over ka to refill, di mo rin masabi kung lumaki na yung butas, useless yung pag stop over mo.
mas mahal at hassle kapag masiraan ka sa rural highway at kelangan mo batakin yung car mo back to marikina compared to getting it fixed. be wise and don't risk it.
March 9th, 2012 03:03 PM #5
i agree to sir mda. anything worst can happen anytime during your trip. no matter how short the distance of your planned stop over. sirit na pala yan at hindi lang patak patak. the pressure and the vibration will contribute to progressive crack on the tubing. mas mahal mag pa overhaul ng engine kesa magpalit ng radiator sir.
high idle RPM at engine start
