38k quote pero nakatawad hangang 33k for mags and tires plus 3k for lug nuts kasi di kasya yung stock tapos lead and tubeless valves bale 36k inabot.Sir magkano score niyo sa Mags and tires niyo? bkt parang ang liit niya para sa isang 16'?
Mukhang maliit siguro dahil sa tires kasi nagkamali yung pinagbilhan ko dapat 195/50 nkakabit naging 205/45 hindi ko na sinoli. Anyway papalitan ko agad to ng 195/50. Benta ko na lang 'tong nakakabit na tires.![]()
Ano nga pala specs ng gulong ng Accent? what to consider pag magpalit ng mags?
1. Offset & Lug Pattern - Ideally have the same offset para hindi masyadong pasok or labas yung rims (will encounter rubbing issues while steering). Lug pattern and distance between lugnuts should be the same para fit.
2. Rim width - Masyadong makapal - same issue as above while steering lalo kapag sinagad yung manibela.
3. Overall diameter - Diameter of the stock rim + tire should ideally be the same as the new rim + tire combination. Meaning, if you increase the rim size by 1" diameter, the new tire must be 1" thinner at the sidewall. Switching to lower profile rims will have negative effects on ride comfort. Using a different combination of tire/rim sizes may result in suspension issues as well as inaccurate speedometer readings.
4. Rim + Tire weight - the heavier the total rim + tire combination compared to stock, the more fuel the car will consume as more effort is needed to overcome the inertia of a heavier object.
5. Cost of tire - Larger rim diameters will require more expensive tires. Ang tires for a 13-16" rim can be lower than 5k / tire, but same tire for an 18" rim will cost nearer to 8-10k / tire.
mga sirs, help naman po sa meaning ng I.C.E, related po ba sa sound set up? and pwede din maka hingi ng advice kung gusto ko mag set up ng sounds, hindi naman pang entry level po. What to buy and corresponding prices. Pls do add the brand name thanks.
ICE = In Car Entertainment. Even a stash of FHM in the back seat qualifies as ICE. hehe
Seriously. Try the folks at Kotseaudioclub.com . They have been a great help to me even now that I'm still a newbie to in car entertainment.
Question lang mga Sirs, totoo ba n hindi maganda or ok ang 195/50 na gulong sa nabili ko mags na 16x7?
Sabi kasi nung napagbilhan ko nung magpapalit ako from 205/45 eh hindi match daw uusli ng konti ang rim kasi mas manipis yung width ng gulong. Although kapag nagcompute naman ng overall diameter konting konti lang ang pinagkaiba ng 205/45 sa 195/50 mga 10.5mm. Napansin ko din medyo nakadungaw ng konting konti ang gulong sa fender / body.
Gusto ko sana yung recommended wheel specs ng accent na 195/50 para sa warranty ng suspension.
TIA
What is the stock size and offset of your existing rims? Ano offset ng bago?
See my post above regarding the Offset and Rim Width. I think this applies to you.
Kung nagpalit ka ng rims, most likely wala na ang warranty ng suspension, even if the rims came stock from another vehicle of the same model (i.e. yung rims ng Accent Blue ilalagay dun sa 1.4). AFAIK this applies for Honda and Toyota. Not sure about Hyundai.
Sir, share ko lang 'tong site (also from this forum). This can help answer your question/s.. Thanks.
Car Bibles : The Wheel and Tyre Bible Page 4 of 4
Share ko lang audio setup ko.
Sub is fired to the back seat. (JL Audio W3V3-4 10" on sealed enclosure)
The Trunk: There is nothing fancy except that I want to it to look as stock as possible. A notable achievement is that we were still able to use 80% of my trunk space.
The space on the left is awaiting my mono-amp (still boston acoustics)....
Latest modification:
Philips Diamond Vision Ultimate White Light 5000k for the headlights
Solarzen Pure Yellow for the foglights
Latest mods (so far)...
Door visor
Chrome handle (I will have this body-color painted on my next visit to casa, cost: Php300/pc, pwde na ba un?)
2din DVD HU with Headrest monitors (for the kids)
Backing camera
Next project/s:
foglights
shoes (195/50/r16)
banana wipers
OSRAM night breaker
mud guard
[QUOTE=dinJ;1901212]Latest modification:
Sir makanO po both bulbs?anu po size ng foglamps bulb? Tnx
Maganda pala itong diamond vision. including installation na ba sa P 1,700. Saang shop?
TIA
