Page 25 of 86 FirstFirst ... 152122232425262728293575 ... LastLast
Results 481 to 500 of 1710
    Jun 2011
    #481
    Quote Originally Posted by andretti View Post
    I can only speak for myself for this one.
    Though I didn't bother to try all fuels, what I did from the start since getting the unit was to use only the recommended fuels.
    Since upto now ala pa knocking issue yung aking unit, its either that I am doing the right thing or just plain lucky with my unit...
    I have been a regular shell unleaded user, pag wala naman its either XCS or caltex gold.
    Up to now wala naman knocking sound yung akin (2500km + on my ODO)
    ako naman trusted ko yung station na pinagkakargahan namin caltex wala pa din akong engie knocking na na experience * 4k odo naunahan ko na yung sayo bro gamet na gamet kase yung saken e hehe. ganon lang din siguro swerte lang kame sa unit namin ni sir adretti
    Jun 2011
    #482
    Quote Originally Posted by bratski View Post
    Sa tingin ko rin nga din na lahat ng 2011 accent may engine knock, hindi kasi laging lumalabas ito at pasulpot sulpot lang. And pag naka on radio mo hindi mo na maririnig. Medyo mahina rin kasi yung sound. Others may not know how to look for it.
    ill try to off my radio mamaya kapag pumasok na ko para makita/ madinig ko talaga kung merun o wala yung accent ko sobrang hina lang ba nang sounds na yon? pero alam ko talaga wala e
    Oct 2004
    #483
    Quote Originally Posted by maxhedrum View Post
    if the sound is similar to 3rd gear shifting to 5th gear, im familar with that sound. so far, no sounds like that coming from my unit. I remember my getz used to have this issue when I'm using unleaded and not premium. nakukuha sya sa timpla ng clutch at gas pero sa premium/xcs di na kailangan ito. could be a design of the hyundai in general on their engines.
    No, its not similar to that sound. Engine lugging yung sound na maririnig mo kung low speed ka at high gear.
    Apr 2006
    #484
    Ok lang sir if hindi marefund basta they replace the unit with one na maassure ako na walang problema. Sama kasi ng experience ko, they wasted my time going back and forth to the dealer for repairs na hindi naman nasosolve.
    Oct 2004
    #485
    Quote Originally Posted by callmenadz View Post
    Sobrang hina lang yung engine knock bro, akala ko din nung una nakaligtas ako dyan sa problem na yan and i keep filling with unleaded pa. Ang kaso most of the time naka on radio ko, nung pinatay ko radio at dumaan ako sa isang tahimik na road (small 2 lane roads with very few cars) ayun tsaka ko narinig yung kararak sound.mas lalabas itong sound na ito pag binebaby mo yung accelerator. Say speed mo 20-30kph tapos apak ng konti sa accelerator then bitaw then apak konti. Sigurado lalabas yan. Kahit flat yung road lalabas din, hindi na kailangan uphill climb. Nagpalit nako ng fuel into petron xcs, nakaka 2 fulltanks nako with xcs and ganun parin.
    Oct 2008
    #486
    from what you guys described eh parang annoying yang sound to the point na kinaiinisan nyo. pero so far ako wala pa naman naririnig na sound na kakabahala or kakainisan ko. its either wala or very faint yung sound na yan.
    btw, rinig ba yan pag closed window tapos walang sounds? ganun kasi ako magpatakbo.
    Oct 2004
    #487
    Yep, kahit closed window and walang sounds maririnig mo. Ako personally kaya naaasar kasi i always try to hear the sound, and pag tumunog na nabubwisit nako. May times naman na hindi ko napapansin kasi either nagmamadali ako or hindi ko na hinahanap yung sound. Minsan mas maganda pa nga na hindi ko nababasa yung problems ng accent dito. Pag hindi ko kasi alam there's a bigger probability na hindi ko mapapansin.
    Jun 2011
    #488
    dito sa sinabi mo na medyo nagalangan ako bro haha! kase yung saken di ko binebaby yung accelerator ko saka pag nag traffic lang or sobrang dami nang sasakyan nag kakaganian speed ko atleast 70-100km normal speed ko. sige bro i trytry ko to mamaya. will update tmr morning if whats happen saken
    +10 dito bro HAHA! parehas tayo masmaganda talaga kapag di mo alam yng problems kase kapag alam mo parang hinahanap hanap mo talaga
    Feb 2010
    #489
    Hi Guys, have anyone tried turning off the ECO system of the car after updating the ECU? My wife is gonna try that, & we will see if there will be additional engine power.
    Jul 2011
    #490
    may i suggest na-ihataw ng ihataw yang gamma engine na yan hanggang tumirik. hwag nyo i-baby. anyway under warranty naman di ba for 5 years. pag may nagsauli na ng makina sa dealers, it will ring alarm bells sa hyundai and bibilisan nila ang remedyo. sometimes saka pa lang nakikita ang problem sa engine pagmalala na.
    share ko lang experience ko sa aking 18yo cyclone engine. dati, parang may mga tansan na nag kalansingan sa ibabaw ng engine pag humahatak ako. after several months and several mechanics and several parts replacement including fuel brands, ang problem ko lang pala ay high tension wire.
    isip ko na baka madaling nagagato yung korean made wires kasi mas mainit dito sa atin. connectivity is not enough. dapat tamang amps or wattage din ang dumadaan and pag degraded yung wires, parang wrong timing or mahina hatak.
    Jul 2011
    #491
    Quote Originally Posted by jayrb View Post
    Sir sino SA mo sa hyundai GH? Si Mon ba nag suggest mag update ng ECU mo? I also went there last Monday to report the knocking sound, mine is 1.4AT. Hindi kse specifically binangit saken ung ECU update coz wala pa daw kelangan i update. Nasabi lang saken they just refreshed/"reset" the ECU. Mejo napansin ko nga ung slow response ng acceleration after lalo na from a complete stop. i had step on the gas a bit more now. Base sa observation ko parang from a complete stop it starts with 2nd gear so i had to step on it much harder para mag downshift.. pero wala na kong engine knock na narrinig after that reset.
    I just had my 5K PMS yesterday and they reprogrammed my ECU. super slow ang response lalo na from a full stop or kapag paakyat. kanina nung paakyat ako ng building parking sobrang hina ng hatak, there was a time na parang walang hatak so I had to really step on the gas. Noticable talaga yung difference. This is not a solution at all..its just another headache.
    May 2009
    #492
    Ako rin, si Mon din SA ko sa Greenhills. after the update ayun, slow response na din. Haay. Sana naman may solusyon na kasi kung hindi mapipilitan din ako na mag request na replacement ng ECU kasi di ko kayang matanggap na 3 months palang sasakyan ko at 1500km tapos ganito ang takbo. mag countdown nga tayo mga sir ng mga nag pa update ng ECU and got slow response
    1. jayvel 1500km Hyundai Greenhills
    Jun 2011
    #493
    just an update kanina nun papasok ako di ko na try yung sinabi ni sir bratski kase may nakasabay akong kalaro very satisfied pa nga ako sa hatak nang accent ko kanina parang mas lumakas nun pauwi na ko try ko na sya at 40-50 speed lang halos di ko na nga inaapakan yung gas pedal ko tas pitik pitik then todo angat pitik pitik ulet wala talaga katagal kong ginaganito yung accent ko kanina ala akong naririnig na parang sa predator then medyo nainip ako medyo dinidiinan ko din nang madiin yung gas pedal ko syempre yon may sounds na talaga nang ngalit sa makina.
    share lang po.
    Quote Originally Posted by spymaker View Post
    ganito ginagawa ko sa accent ko tas kapag yung daddy ko lalo na talagang yung rpm nya halos umaabot lagi sa red line. * 4k odometer na sya. sabi pa nga nang daddy ko kapag 5k+ na pwd na namin i sagad yung top speed nya at 160-170 daw. i suggest lang po na hatawin nyo mabute yung accent nyo. baka sakaling mawala yung engine knock na yan.
    and also
    nahihinaan ko din yung accent ko kapag nag fufull stop. sa arangkada talaga malakas ang accent for me at 40-100km. kung nahihinaan na ko sa pag full stop nang accent paano pa kaya yung kapag nag pull stop? saket talaga sa ulo yan. sana maayos na talaga nang hari yung issues na to sa accent natin
    Jan 2011
    #494
    Quote Originally Posted by milo101 View Post
    Yep, if it really affected the response in a major way yan ang problema. Isipin lang natin na ang makina natin is just 1.4 kaya we should not expect it to be like the 1.6, the problem is baka its worst than a 1.3...
    Quote Originally Posted by jayvel View Post
    Eto pinagtataka ko e, why is Hyundai updating the ECU of the Accent and at the same time honoring to replace some ECU of owners complaining of slow response this to to have the earlier settings since as stated di raw maibabalik sa earlier setting if updated na ang ECU?
    Hyundai should only have one solution for this lalo na parang dami na ng affected...
    Oct 2008
    #495
    hataw lang ng hataw. inip na inip na nga ako madala ito sa nlex and sctex. ilang araw na akong parang detective dahil sa sounds na yan. wala talagang kakaiba so enjoy the ride na lang ako.
    share lang po.
    and also
    Jun 2011
    #496
    kung matic yung sayo bro pahilahin mo yung mga low gear mo wag ka muna mag + - yung saken nag + - ako nang maaga below 1k pms dapat daw pahilahin muna nang pahilahin yung matic mo eto yung nagiging patern nun saken kapag pinapahila nang daddy ko
    2nd gear 70-90 4-5rpm nato
    minsan 100 pa nga :D kapag nabibitin yung rpm nato nasa 6 na which is redline saglit lang naman baba din agad
    3nd gear * most 90-120 lang di nababatak to mabute.
    4th gear 120-140
    bat alam ko yung gear e naka drive? e syempre hehe. mararamdaman mo naman yun e :D
    share lang ulet
    Oct 2008
    #497
    pre, kakatakot naman yang gear change mo hehehe. pero sa matic ko, pansin ko sa akin pag nakafourth gear na, tapos nasa 2000 rpm, minsan bumababa sya papuntang 1800 pero 4th gear pa rin sya tapos wala namang change sa speed ko (increasing pa nga ako eh). feeling ko tuloy parang me 5th gear eh...
    4th gear 120-140
    share lang ulet
    Jun 2011
    #498
    hehe dito din natin makikita kung matibay ba ang hyundai. di ko yan pansin bro yung rpm ko usually kapag naka 4th gear na nasa 2000 pataas * most 80-100 speed ko pag ganon.
    Oct 2004
    #499
    Swerte nung mga hindi nakaka experience ng engine knock, siguro partly due to naihahataw nyo mga rides nyo. Ako city driving, pabalik balik quezon city and manila. Hindi ko pa napapaabot ng 70kph amg accent ko. Wala naman kasing road dito sa metro manila na pwedeng patakbuhin ng more than 60. Unless sa gabi or madling araw. Yung 60kph ko nga panandalian lang. Average speed ko nga according sa multi info meter ko is 11kph lang.
    By the way, yang eco meter na yan walang kinalaman kung lalakas o hihina ang hatak pag naka on or off. Its just a reminder kung economical ang driving mo (it lights up).
    Feb 2010
    #500
    By the way i understand that ECO system is something to do with the throttle just stumble the info on the net. see below
    For 2012, the Elantra gets Active Eco, joining the 2012 Accent and 2011.5 and 2012 Sonata.
    When it is switched on, Active Eco changes the throttle map, which means that the throttle opens less (and a bit more gradually) for a given press of the gas pedal. Floor it and the throttle opens wide, but at part throttle, the car will take off gently and deliver better fuel economy.
    It also lowers the shift points for the transmission, and cycles the A/C compressor on/off when A/C is in use.
2011 Accent AT - Engine Knock!
