Results 7,671 to 7,680 of 8077
December 31st, 2018 05:23 AM #7671
January 1st, 2019 02:52 PM #7672
Rack and pinion kumokontra yung steering wheel intermittently pag nakasagad sa left or right bro. Minsan kahit di naka full lock kumokontra din pakonti konti. Rack ends pag nakataas sa lifter at may wobble yung tire/s when you try to wiggle them left to right by hand. Stab links usually makalampag and malikot yung steering ng konti on rough roads.
Might be my route din bro. GS's route was mostly C6 when it was still under cobstruction. Although compared to the body on frame vans like the Hiace mahina talaga rubber suspension bits ni Hyundai.
60Tkm lang ba yung timing chain? Ang igsi pala ng lifespan nya. Others are up for replacement at 100Tkm... Nagpalit ka din nung chain tensioner?
January 2nd, 2019 06:49 PM #7673
Di ba lifetime pag timing chain? Ang alam ko na 60k km e timing belt.
January 2nd, 2019 08:42 PM #7674
^ang pagkaalam ko is 80k yung timing belt, but now, like the Toyota Innova it's 120k. Correct me if I'm wrong.
Timing chain is supposed to last the lifetime of the car, but you have to have it checked once in awhile to be safe.
Sent from my SM-T705 using Tapatalk
January 2nd, 2019 10:14 PM #7675
Di ba timing gear yung lifetime ng vehicle? Timing chain din ba? Sabi nababanat din yung chain over time kaya pinapalitan din. Not sure lang how long before palitan. Siguro pag lampas na sa tolerance yung haba.
Lahat ba ng GS na VGT timing belt or may models na timing chain? Is it the same for HARI and gray units? Ours is a 2011 Euro 4 gray market unit.
January 3rd, 2019 12:11 AM #7676
Hindi lifetime ang timing chain. Papalitan din yan. At least 100k or more. Tignan ko sa manual ko.
January 3rd, 2019 03:10 AM #7677
Afaik, all vgt models ay chain while tci model is belt
January 10th, 2019 03:31 PM #7678
Been hearing a whining noise everytime i start the van in the morning. Seems to be coming from the PS pump. Fluid level is ok.
It goes away when the engine is hot.
Anyone experienced this before?
- 54,258
January 10th, 2019 10:08 PM #7679i don't starex.
but i believe it is coming from an ill-lubricated bearing. it is probably one of the pulley bearings or idler bearing or...
some cars have replaceable bearings, and in some cars, one has to replace the entire part.
WD40-ing it will make the noise go away, only to return after 1-2 weeks.
another possibility is the belt. sometimes, tightening it solves the problem.
January 11th, 2019 01:40 AM #7680
Although the ps pump is always the prime suspect (low ps fluid causes this noise) any bearing outside can cause a whining sound. So anything that the serpentine belt passes like the alternator, water pump, ac compressor and serpentine belt tensioner must be checked. Try to pinpoint the source using a pvc pipe. With one end close to your ear point the pipe as close to any suspect part (pump, bearing) and if the sound is loudest then that is your prime suspect.
That's what he actually did. He also retrofitted an eps to his 1970s era beetle. Btw, now...
A/c
