Results 7,561 to 7,570 of 8077
August 14th, 2018 07:48 PM #7561
Dalawa pa lang naman ang generation ng starex. 1st Gen, 1997-2007 / 2nd Gen 2007 - present.
August 18th, 2018 06:08 PM #7562
ATF PREMIUM HTP | Petron
Mag pa ATF exchanger ako sa Petron marcos hiway. sana available yaan ATF premium HTP.
kung saan san ako nag hahanap ng Red-1 (pero bakit Red 1-"K")
At wary ako bakit "suitable" ang description at hindi exceeds or meets
Sana ok quality nito.
- Apr 2012
- 3,469
August 19th, 2018 02:56 AM #7563
August 19th, 2018 06:04 PM #7564
Php281/liter ATF HPF, 215 ordinary
1300 labor
para sa ATF exchanger / dialysis, pa kwento po ng procedure.
pinakita ko ang manual saying 10 liters ang ATF capacity ng A2.5 engine ng GS VGT.
puzzled sila kasi 5 liter lang daw nilalagay nila. after ma flush using 5 or so liters din...????
pag drain ba nang atf exchange machine (after cleaning, flushing at before ilagay ang fresh ATF)
0.00 ZERO Liters ba ang laman ng AT transmission or may laman ng XXX liters?
sabi nila isang paraan is sukatin kung ilan liters nilabas ng transmission, e di ba parang drain lang sa plug yuu na may maiiwan sa looban ng transmission?
kung parang gravity drain lang -- safe ba to assume yun naiwan na ATF sa loob ay clean and fresh na rin kaya 5-6liter lang isalin na fresh ATF to complete the 10 liters ATF capacity?
so ilan liters ba ilalagay na fresh ATF after cleaning?
in absence of dipstick may sukatan ba like a bubble window?
thanks
August 19th, 2018 06:30 PM #7565
marami naiiwan sa loob especially sa mismong torque converter. most transmissions have a level overflow hole... this prevents overfilling
August 21st, 2018 03:06 PM #7566
Flushed using 4liters. Clean red na itsura.
Put back 5.5 liters as final fill.
Sabi ng operator, Atf exchanger did not drain-higop the torque converter but it was flushed with clean atf. So naiwan na atf is 4-5 liters and as clean as the fresh open bottles na additional 5 liters to complete the 10 liter ATF capacity.
I hope that Red-1 rating is true.
Plan to use this petron atf maybe 20-25k kms just to be safe.
- Apr 2012
- 3,469
September 7th, 2018 12:42 PM #7567May nagpalit na ba ng shock absorbers dito? Magkano inabot?
Sent from my SM-J730G using Tapatalk
- Apr 2006
- 351
September 11th, 2018 11:47 AM #7568
September 12th, 2018 01:00 PM #7569
Better get OEM shock absorbers. Baka mag-iba kasi ang ride kapag replacements ang kinabit. Ganda pa naman ride ng Grand Starex.
- Apr 2012
- 3,469
September 12th, 2018 06:29 PM #7570
Oh yeah you're right! I think I'll re-watch the film tonight
2009 Lotus Esprit
