Page 588 of 808 FirstFirst ... 488538578584585586587588589590591592598638688 ... LastLast
Results 5,871 to 5,880 of 8077
    Apr 2012
    #5871
    Kumho for the win!
    #5872
    Guys,
    What's the bulb for our reverse lights?
    #5873
    Pabuksan mo na lang bro...
    Forgot to take note of it when I opened up my taillight assembly because of a loose bulb...
    And our owner's manual is useless....
    Apr 2012
    #5874
    Byahe ako sa Pampanga sa Wednesday with full capacity, pero nag aalangan ako sa nakalagay na tire pressure sa manual na 51 rear. Di kaya delikado yun? Parang ang tigas na masyado nun
    #5875
    Guys,
    peanut bulb, p21 if my memory serves me right.
    nakabili ako dati ng philips p21 for the reverse light, much brighter than the stock. pero di ko din kinabit kasi i modified my rear lights cluster. the signal lights (which are bigger) became the reverse lights and the reverse lights became the signal lights. I also put a 55 watt h4 bulb in the reverse lights. pag may naka-high beam sa likod ko sa stop light i put it on reverse balak ko nga lagyan ng switch para sa mga ogag na nakasunod sa nlex na naka-high beam.
    #5876
    45 psi max lang, matagtag na nga pag 47 psi e.
    #5877
    Ayos iyan, bro..... Para mabigyan ng leksyon ang mga ogags nating kapwa motorista....
    Am using between 42-45 PSI on all tyres....
    “The measure of a man is what he does with power – LJIOHF!”
    24.7K:luvmenot:
    #5878
    *yebo
    I recall your rewiring. Heheh! Walang kawala.
    *cvt
    Tnx. Medyo kulang nga sa info but at least english naman. Gray market guys get it in korean.
    Apr 2012
    #5879
    47 normal tire pressure ko pag normal loads. Sabi kasi sa manual 51. I wonder if it applies here
    Apr 2012
    #5880
    Sir yebo pag napundi na reverse lights ko patulong naman pag modify ng ganyan
2008 Hyundai Starex (Gen. 4)
