Page 586 of 808 FirstFirst ... 486536576582583584585586587588589590596636686 ... LastLast
Results 5,851 to 5,860 of 8077
    #5851
    Buo yata palitan ng blade sa likod ng Grand Starex. Kasama yung pinka frame niya.
    oo nga pala.. well, if TS is handy with his hands, he can buy just the refill rubber, and use long nose pliers to insert it in the blade holder..
    i use refill rubber blades.. 120 bucks a pair..
    #5852
    for 650 pesos, you can probably get 2 to 4 of those from the mall. of course, quality and prices differ.. there are very nice ones, and there are not-so-nice ones..
    Di kakasya sa GS yung mga generic wiper blades, yung design nya kasi kailangan yung specific na wiper blade lang para doon.
    Apr 2012
    #5853
    Di ko nga maintindihan kung paano tanggalin yung rear wiper.
    #5854
    Came from the Cash and Carry area in Makati and had just crossed the tracks when I heard something hit my rear glass, though lightly. Surprised to see this leaning against the glass:
    D*mn, right? Didn't feel that it had any adhesive on the sides, so I turned it over. Wala din.
    When I got to the parking, went to the back and tried installing it. Apparently it snaps on (assuming you've gotten it installed the right way). There are grooves to keep it on, like these:
    I tried hitting the mirror, the metal pole where it's attached, the door -- everything! -- to dislodge it. So far so good na.
    So if you guys have the time, check that your rear mirrors are securely snapped on.
    Jul 2014
    #5855
    Good morning. I just want to ask if any of you changed your tire jack to a hydraulic bottle type or crocodile jack? How many tons ba dapat for our GS?
    Posted via Tsikot Mobile App
    #5856
    Quote Originally Posted by Mik721 View Post
    My guess would be at least 3 tons
    #5857
    Agree. Not sure if the 2 tonner would be enough. Also check if the croc can handle the height requirement for the GS.
    #5858
    ^kayang-kaya ng 2 tons. curb weight is only 2,250kg plus payload 1000kg (ang tataba na ng mga pasahero mo nyan) = 3.25 tons/4 wheels = 812 kg per wheel.
    pagawa ka ng metal plate sa welding shop na at least 10 inch x 10 inch x 1/4~1/2 inch thick para patungan o base ng jack. you'll never know if you need to change a flat tire on sand or mud. bale wala ang jack kung lulubog lang sa lupa.
    Jul 2014
    #5859
    Thanks. Better ba Ang crocodile type (though it would take more space) or pwede na yung bottle type na 2 tons?
    Nov 2007
    #5860
    first 2 tires i changed were into bridgestones that were only 99 load for 5.5k each. ride was better with the bridgestones replacing a pair of nexens.
    then i just recently changed my last pair of nexen tires to kumho portran. finally may nahanap ako na malapit sa amin. 215/70r16 na with the right load rating. best of all, it's only 4.6k per tire! ride is still smooth as ever
    Nag-oblong na nexen tires ko at 45k kms.
2008 Hyundai Starex (Gen. 4)
