Results 4,881 to 4,890 of 8077
- May 2006
- 913
November 8th, 2013 08:16 PM #4881i was looking at the GRX engine layout.. and the intake manifold is quite different to the GS engine intake manifold.. unfortunately posting pics here still confuses me. heheh..
November 8th, 2013 10:43 PM #4882
Done! changed oil kanina 1pm using motul specific, then went to ace to look for materials and buy a cutting disk for my grinder.
yup, 10 minutes is more than enough time for the install if you have the blanking plate on hand. it took me another ~45 minutes to fabrictae the plate using the gasket as a pattern. i used a Yale door lock hasp for the plate, cost P109. wala ako makita na steel plate sa ace but saw some materials there that can be used - a painter's scraper, a mason's trowel, and the Yale hasp. the hasp was the thickest of the 3. meron pa nga stainless steel hasp pero nag-alangan ako baka hindi kaya ng drill bits ko sa bahay.
i only ran the gs in the garage, 4pm na ko natapos and it was raining. walang CEL. i will try tomorrow on the road.
next one will be the sorento by tomorrow afternoon.Last edited by yebo; November 8th, 2013 at 10:55 PM.
November 9th, 2013 04:31 PM #4883
Iyan si bro,yebo..... DIY....
Where did you blank it bro....?
How is it today???
November 9th, 2013 05:25 PM #4884
dun sa naka circle sa post ni IMm29.
balak ko sana dun sa inlet ng egr kaso madami aalisin, e kung mag cel baklas na naman so change of plans to what works already.
ok naman kanina, parang lumakas ang hatak ng konti, placebo effect hehehe! pero that could also be the oil at bagong palit din kahapon, first time to use motul.
di ko magawa sorento, ginamit ni misis hangang ngayon wala pa.
- Oct 2013
- 41
November 9th, 2013 05:34 PM #4885hi to all gs owner, after blanking my egr last month,i have successfully installed my GREEDY oil catch can last nit, the occ, hoses, clamps and bracket came from zix 888 but the installation was DIY.
November 10th, 2013 02:47 AM #4886
Nice bro. Diy-er talaga! Destroy yung D ko kaya pass ako sa DIY hehe!
I was telling Zix 888 that feeling ko placebo lang at first, kasi parang gumaan. Then i started flogging it, immediate yung response! I even floored it sa driveway ng rcbc, pero by accident. Burnout, pwede ipalo yung pwet. And all this with 10 month old oil due for replacement.
Posted using TocinoTalk
- Apr 2012
- 3,469
November 10th, 2013 02:55 AM #4887Ppa blank na ako nxt month. Napansin ko kahapon sa MOa iba engine layout ng Gs ko kesa dun sa display. Dun sa part na naka circle parang iba nakalagay sa akin dyan. May parang plastic dun na may screw na may siemens na brand. Btw grey market unit akn
Sent from my SGH-I717R using Tsikot Car Forums mobile app
Tsikot Member Rank 1
- Jul 2009
- 4,090
November 10th, 2013 04:10 PM #4888
November 10th, 2013 04:37 PM #4889
Long drive galore! Sarap ilaro sa SLEX kagabi.
- Jul 2009
- 4,090
November 10th, 2013 04:53 PM #4890mas maganda effect ng blanking sa inyo(GS). on other engines, at idle and low rpms lang commanded open ang egr valve, kaya after blanking, sa low rpm talaga maramdaman, but sa gS, commanded open ang valve by ecu at different ranges ng rpm, kaya ang effect will be felt not only on low rpms
I use imgur.com. Upload the picture there, then get share links, choose bbcode and paste here.
Mineral , semi synthetic or fully synthetic?
