Results 1 to 7 of 7
    Jun 2010
    Need help po, I have problems with my water reserve sa honda lxi 99 ko. Ang bilis mag-empty nung container. Siguro after 3 days lang mag-empty siya. Nagpalit naman ako ng radiator cap and pinacheck ko narin kung may leaks. Wala naman. Baka meron po kayong same experience or suggestion what other things to check. Thanks in advance.
    Apr 2009
    Ganyan din yung sa ESi ko dati. Although in my case hindi na kasi tight yung seal nung tank (maluwag na sa bukasan) so obviously when things heat up mag-eevaporate palabas yung steam ng water that recirculates in it. Kaya yun, nababawasan yung laman ng water reserve tank.
    Jun 2010
    Quote Originally Posted by isa1023 View Post
    thanks isa1012 - Pano ko po yun matetest?
    other things you might want to check:
    -water pump
    -engine oil for water contamination (deposits under the engine oil cap should look like mayonaise if its bad enough)
    Napa check mo na ba radiator mo baka barado at subukan mo munang tanggalin radiator cap at start mo makina i rev mo ng malakas tignan mo kung sumusuka ng tubig palabas sa radiator isa lang symptom ito na worn out na head gasket mo. Kamusta naman reading ng temperature gauge.
    Quote Originally Posted by speed unlimited View Post
    *speed_unlimited : tell us more about checking for worn out cylinder head gaskets and the usual places and costs to have them fixed please ... I suspect my ride needs a new one
    Oct 2009
    try mo iistart ng walang rad.cap kung blown na gasket mo pag istart mo palang nyan titilipon na agad ang tubig sa radiator mo....ung ang isa sa mga sign na blown gasket....
water reserve
