Results 11 to 20 of 20
- Jul 2011
- 10
July 19th, 2011 10:34 AM #11hi, it started last year and only happen when it rains. Had it looked in a shop and they added sealant on rubber on top and on the sides. Then it stopped for a while. After a week when it rained, it leaked again and i notice it appears slowly specially when i step on the brake. They added more sealant and even removing the rubber strip on the windshield. It stopped for a while but after sending my car to the carwash eh ayun, even worse than the first one.
July 19th, 2011 10:39 AM #12
^if the leak really came from the windshield mouldings then better to have everything remove and re installed.
go to Aguila probably
- Jul 2011
- 10
July 19th, 2011 10:45 AM #13as much as i dont want to have it removed and reinstalled but it seems this is the last option. Any recommendation where to have this done? prefer to be somewhere south area.. thanks..
July 19th, 2011 10:49 AM #14
Aguila glass. yeah it's really hard to have windshield removed but since meron ng leak then no choice but to do it
- Jul 2011
- 10
July 19th, 2011 11:32 AM #16
^don't know but you can probably ask them to do so, haven't you done a water leak test yourself to see where the leak is coming from?
- Jul 2011
- 10
July 19th, 2011 02:56 PM #17havent done it. am reading on some procedure to do it, like removing the interior and pour water to see where the leak is, baka lang kasi di ko na maibalik eh mas problema.Will try all my options over the weekend. Thanks!
November 22nd, 2016 08:55 AM #18
i experienced this over the wet weekend we just had. i'm wondering how the ts solved this watery curse
this video shows the problem i have although i think the owner of the usdm civic fd has it worse. pero doon na din siguro papunta ito kung pabayaan ko
i wonder if the suggestions to fix this problem on the comments section will work. if not then i guess going to aguila glass to have the windshield resealed is the only solutionLast edited by baludoy; November 22nd, 2016 at 08:57 AM.
- 52,731
November 22nd, 2016 09:16 AM #19we've experienced something like that, in our non-honda cars.
the problem turned out to be rust. the rusted metal under the rubber compound had to be cut away and repaired. we were advised then, that without the metal repair, no amount of re-sealing will result in a permanent cure.
November 22nd, 2016 07:06 PM #20
No rust naman from the inside. I already checked and removed the a pillars garnishing. Hopefully when i peel back the plastic trimmings of the it'll show no rust underneath
to be or not to be, that always confuses me!
high idle RPM at engine start
