Results 1 to 10 of 20
- Jul 2011
- 10
July 18th, 2011 04:42 PM #1Hi, hope you could help me with more ideas to fix this water leak on my ceiling. Before i can only experience this when it rains but now even on a simple carwash water would continuously drip on both end sides. I had added sealant, removed the rubber and added more sealant but the problem is still there! help.... thanks...
- Jul 2011
- 10
- Jul 2011
- 10
July 18th, 2011 04:54 PM #3Civic 2007 -Experiencing water leak on the passenger's and driver's side. Before this only happen when it rains but even after plavcing sealant and removing the rubber on the windshield and adding more sealant the problem occurs even on a simple carwarsh! help as this is becoming so frustrating now...
July 18th, 2011 05:10 PM #4
Have you found the source of the leak? Is the cause a loose rubber seal that won't seat properly or a misaligned door?
- Jul 2011
- 10
July 18th, 2011 05:27 PM #5hi, still not found and actually becoming worse as just a normal carwash, water would still drip after adding more sealant. any other possibilities?
July 19th, 2011 08:43 AM #6
Note thou that "adding sealant" on a misaligned windshield does not automatically mean "solving the problem". If the cause is the latter, you would need to align it properly first before re-applying sealant.
- Jul 2011
- 10
July 19th, 2011 09:49 AM #7Thanks. will try this over the weekend and hopefully this would address my problem. Any recommendation where this should be done?
July 19th, 2011 10:09 AM #8
did you replace your windshield recently? I think you should have your windshield re-installed and if you can replaced all the mouldings with new ones
- Jul 2011
- 10
up for suzuki
Let's keep our Chapter Alive! ATO NI Mindanaoans!
