Originally Posted by
Egan101
If you're planning to get a 6th gen Accord (1998-2002), make sure you get the model with the 2.3L engine. Halos same lang fuel consumption sa 2.0L model but you get more oomph. The 6th gen Accord has a light chassis (around 1300+ kg) which is comparable to the current crop of compact cars. The steering is one of the best I have tried, lots of feedback and very responsive. The F23 engine offers a good amount of torque at below 2k rpm. Press the gas pedal harder, let the VTEC kick in, and the tach will easily rise to redline (past 6k rpm). The 4AT tranny is not that quick but it's good enough to get the car going from 0-100kmh in just over 9 seconds. Key points to watch from this model are its power steering system (prone to leaks), a leaking air conditioning system which can potentially bring down its compressor, and a sliding AT tranny in case the previous owner was not to keen to change the ATF. The 6th gen Accord is more mechanical compared to the newer Honda cars so maintenance is not that extensive, just change fluids and filters regularly. The F23 engine is quite robust and not prone to failure (even in the event that the car overheats due to a leaking radiator). Unless you have a broken engine or tranny, most common parts are available from shops who cater to Honda cars. If you can find the 2.3L MT model, go for it (they are quite rare though) as you will have no worries with a sliding AT tranny. It might be good to upgrade its stock 15" rims to 17" to give it a better look as the stock 15" rims look small for the car. FC is around 5-6 km/L for city driving and 8-9 km/L on the highway. Just don't keep tach rising past 3k rpm so that FC will be more manageable.
Also, stick with the 2001-2002 model years as LTO had a different MVUC cost for cars 2000 and older. Midsize cars from 2001 have a lower MVUC (registration) cost. The difference is about 2k in registration cost.
