Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Sep 2008
    What RPM po nag tritrigger ang VTEC ng 97 na civic vti?
    May 2007
    It kicks in around 4,500 to 5000 RPM depending on your throttle position.
    Sep 2008
    Quote Originally Posted by v6dreamer View Post
    Pwede po paki explain yung throttle position?
    Jan 2009
    sir on my vti 98, sa 3200 nag eengage ang vtec, kabit ka ng vtec light para alam mo pag nag kick ang vtec mo
    Sep 2008
    Quote Originally Posted by nurv08 View Post
    VTEC light, interesting. San po nakakabili nun and how much?
    Oh yeah!
    Sep 2004
    Depende sa VTEC variant. There are different VTEC engines kasi eh (SOHC VTEC, DOHC VTEC, SOHC VTEC-E, i-VTEC, etc.)
    Yung VTEC ng 97 Accord kicks in at 2.2k rpm. How do I know? Hehehe, I installed a VTEC light. (Although since sira yung VSS ko, ayaw gumana ng VTEC ngayon :sad
    From what I learned over at HCP, yung DOHC VTEC kicks in at ~4.5k, while the SOHC VTEC is around 3.5k rpm.
    Re: VTEC light, check mo sa internet how to do it. Walang kit na nabibili para diyan, lahat DIY (AFAIK). Also, wala pa yatang nagkakabit ng VTEC light for i-VTEC engines. Puro SOHC/DOHC pa lang. Either you tap the VTEC solenoid or the ECU pin.
    My VTEC light:
    Quote Originally Posted by richiegonzo View Post
    Actually, you can do this yourself. No soldering. Simple wiring and one LED bulb. VTEC yo!
    Oh yeah!
    vtec YO!
    Apr 2004
    ang sarap ng "wooooo!" nung kumag sa pic hahahaha
    patingin naman ng diagram naman kung pano i-wire yung vtec light na yan?
    di ba delicado?
    Jan 2009
    yon mga taga batangas na gusto vtec light, pm nyo ako, bigay ko na lang yon labis na materials ko sa vtec light
    Jan 2009
    sir di naman delikado, i installed vtec light a month ago, ok naman, nag tap lang ako sa solenoid, ayaw ko kasi mag tap sa ECU baka masira, hehehe, bale kelangan soldering kasi kakabitan mo pa ng resistor yon LED para di masunog kasi yon nabibili na LED kalimitan eh 3 volts, kung 12 volts naman led mo wala na resistor. may materials pa ako for vtec light, yon mga taga batangas contact lang nyo ako, bigay ko na yon mga materials. hehe
    Sep 2004
    Simple lang gumawa ng DIY VTEC light. All you need is 3v LED (better kung 12v para wala ng resistor), 1 kilo-ohm resistor, 12-gauge wire, soldering gun, soldering paste and electrical tape.
    Solder lang yung resistor sa positive leg ng LED. Then tap via the 12-gauge wire, dun sa VTEC solenoid connector, para wala ng splicing. Ung other end of the wire, to any negative terminal ng kotse (chassis, negative node ng battery, etc.)
    It was fun at first, but the novelty quickly wears off.
    Sep 2008
    Thanks everybody!!! Just got home and hinataw ko for a while sa commonwealth yung 97 VTi SOHC ko. It felt like nag kick in at 1.4k RPM yung VTEC. What a rush!!! just got my civic last month so hindi ko pa talaga sya kabisado. any help is gratly appreciated po. Like things I need to watch out for for this particular unti. Like hi tension engine and suspension upragrdes. Im planning on street set up. so im calling on all civic experts to chip in their two cents worth, any input is most welcome po. budget is quite tight at the moment kaya budget consideratons should be taken into account. Pls feel free to share your valuable knowledge. BTW, SOHC lang po itong unit ko. very stock pa din po, escet the muffler. also ple recommend a good suspension shop na ok ang trabaho without being pricey. QC fairview area lang po sana.
    Sep 2008
    Thanks everybody!!! Just got home and hinataw ko for a while sa commonwealth yung 97 VTi SOHC ko. It felt like nag kick in at 3k RPM yung VTEC. What a rush!!! just got my civic last month so hindi ko pa talaga sya kabisado. any help is gratly appreciated po. Like things I need to watch out for for this particular unti. Like hi tension engine and suspension upragrdes. Im planning on street set up. so im calling on all civic experts to chip in their two cents worth, any input is most welcome po. budget is quite tight at the moment kaya budget consideratons should be taken into account. Pls feel free to share your valuable knowledge. BTW, SOHC lang po itong unit ko. very stock pa din po, escet the muffler. also ple recommend a good suspension shop na ok ang trabaho without being pricey. QC fairview area lang po sana.
    Here's my plan:
    Tanabe DF210 Lowering spring with 1.5" drop (NORMAL RIDE)
    15" mags
    hight tension wires
    split fire spark plugs
    Racing filters K n N or Apexi
    strut baR
    H/E set-up kung may pera pa.
    Suggest lang po kayo ng shops na ok ang trabaho, kung meron sa faiview/QC area mas ok po.
  16. #16
    Oh yeah!
    d ba nilampaso lang din yan nila paul walker at vin diesel?
    sensation ng vtec parang "false turbo" ata,e hehehe.. feeling mo biglang sisipa hehehe
    vtec light hmm.. maroon palng accessory na ganun...kala ko turbo lang nilalagyan ng ganun..
    Aug 2005
    your 97 vtec is actually has a vtec-e engine. it shifts from 12 valve to 16 valve mode to save on fuel. it doesn't have a 2 cam profile like the b- series engines. if you want to make it fast, find a 20 lobe d15 head (complete with ecu and distributor) and slap it on your engine block. but if you want real power, i suggest you save up and install a turbo kit instead.
    Sep 2008
    Quote Originally Posted by ejaydpogi View Post
    can you please explain further yung 20 lobe d15 head? magkano po kaya ito? turbo is very expensive eh, nasa 100k ata!!!!
    Jan 2009
    DIY VTEC indicator sa kapwa kong naka FD.
    [ame="http://www.youtube.com/watch?v=B4KIXXYyjug"]YouTube - diy i-vtec light[/ame]
    Apr 2004
    Here's my plan:
    15" mags
    hight tension wires
    strut baR
    1. 1.5 drop is ok
    2. 15 is ok. i have 16s on my 99, ok din naman. mahal lng ng quality new tyres.
    3. high tension wires... yung stock wires ok naman. fatter wires, more resistance.
    4. plain bkr5 or bkr6e is reliable and cheap. you won't need those fancy splitfires if you're not running high boost from turbo. won't make your car go any faster, so i suggest stick to the plain plugs.
    5. racing filters... ok din naman. my experience, parang iba ang sound. over long distances ang sakit sa ulo (for me at least).
    6. strut bar, sa engine bay? ok.
    7. headers/exhaust... don't buy too large diameters else you will lose bottom end power (torque).
    simple i/h/e konti lang naman gains nyan (not like GT1, headers lang kita mo na yung results). i suggest you hit the honda club of the phils forum tech area for some tips on how to build a quality all-motor ph16.
VTEC Question
