Results 1 to 10 of 21
June 10th, 2008 03:27 PM #2
No its not. Its a standard VTEC. VTEC-E was the one where the engine was designed more for fuel economy, AFAIK sa Europe lang nilabas ito... It was also found in some Accord's and Integra's...
June 10th, 2008 03:39 PM #3
ang vtec-e po ay sa d15b series na makina...
three implementations:
1. economy - vtec-e
2. aggressive
3. 3 stage
June 11th, 2008 11:41 PM #4
i always thought the vtecs of the EKs released here had the vtec-e assemblage. so if they're not vtec-Es, what are they?
June 12th, 2008 03:08 AM #5
^ ph16 po... standard lang yung vtec dito satin. it still uses all the 16 valve.
vtec-e is part of the d15b series. this vtec uses only 12 valve on normal and city driving then kung hataw dun gagana lahat.
June 12th, 2008 08:58 AM #6
so standard vtec lang pala iyong ph16. kaya pala malakas sa gas
so sa 7th gen civics na nakatalaga ang mga vtec-e engines dito sa atin (the ones w/ vtec3 ES cars )?
how about the FDs w/ k series engines? parang vtec-e din ba siya?
June 12th, 2008 09:14 AM #7
FD Civics for 1.8L is the R18 engine its i-Vtec. Same with the FD 2.0 K20 i-Vtec din... i stand for intelligent...
June 12th, 2008 10:06 AM #8
June 12th, 2008 10:19 AM #9
eto para medyo malinaw kaya lang mahaba pag binasa, check this link http://www.allgonoshow.com/news/04/k...tec-breakdown/
The K20A3 does not have a standard DOHC VTEC valvetrain as we know it from the B-series engines - the K20A3 should actually be called a “DOHC i-VTEC-E” engine, because it uses a VTEC-E cam setup. The K20A2 is the “real” DOHC i-VTEC engine, utilizing the standard DOHC VTEC cam setup we’re all familiar with.
June 12th, 2008 10:31 AM #10
One feature they should incorporate in EVs is speed limiting based on the keyfob you hand over to...
