Results 31 to 40 of 44
- Mar 2014
- 901
March 29th, 2016 01:11 AM #31Check muna throttle body, baka it needs cleaning dahil marumi. Check muna air filter, baka it needs replacement na. And fuel filter too.
Sent from my UP+ using Tapatalk
- Jul 2012
- 329
April 16th, 2016 04:33 AM #32same solution solved the issue.. ignition coil is the culprit. nag back read ako nakita ko nag comment rin pala ako na palitan ignition coil to solve this issue. i did before pero my mistake was replacement part binili ko.. lasted for a year then eto bumalik nnmn. nag linis nko tb, iacv, replaced pcv valve and hose, checked alt, batt, checked compressor and fans, even adjusted tappets.. na resolved lang nung pinalitan ko lahat ng surplus ignition coils!
now my car runs fine kahit may AC, pero nung na trafik ako sa QC sa kainitan ng araw, ayun maramdaman ko yung jerk at pag stall ulit. issue na ng honda yung ignition coils na pumapalya.. time to buy bnew orig honda ignition coils.
- Mar 2014
- 901
April 17th, 2016 12:48 AM #33It is better na brand new, kaysa surplus ignition coil.
- Jul 2012
- 329
April 21st, 2016 05:20 AM #34
- Mar 2014
- 901
April 21st, 2016 08:26 AM #35A replacement will do, at least brand new. If you find the OEM from Casa much expensive. Surplus parts mostly here in our country are not surplus, they are used parts already.
- Jul 2012
- 329
- Jul 2012
- 329
- May 2011
- 189
June 2nd, 2016 10:41 PM #38Same here. 2012 honda jazz 1.3 MT.. pgstuck ako sa traffic tapos nirev ko yung engine. after umakayat ung RPM Babagsak sia sa round 400RPM at manginginig bago bumalik sa around 600-700RPM pg naka idle. normal ba un? Kung no rev. 600-700RPM then pgmagoon un fan nasa 800RPM wlaang nginig. Pgnagrevrev lang at bumagsak na sa baba un needle.
- Jul 2012
- 329
June 17th, 2016 03:15 PM #39reason why nag jerk car kasi mababa ang rpm. dapat nsa 700 to 900 ata pag idle.. tapos sasabayan pa ng aircon.. lalo mas kailangan mas mataas na rpm. ignition coils may not always be the culprit.. pero possible kasi pag kinapos ng bato ng kuryente from coils to plugs ayun babagsak nga rpm.. pwede rin yung iacv madumi na.. need linisin. kasi alam ko nakaka apekto rin yun kapag idle ang jazz natin. better have your iacv checked and cleaned.. pag wala parin consider changing the spark plugs, pag wala parin check mo pcv valve and hose baka may leak, pag wala parin be ready to buy a bnew set of ignition coils. based from my experience ito ha.. everytime nangyayari sakin ito, ignition coils palagi ang nakaka solve ng issue. another way to check kung coils nga eh kapag nararamdaman mo na parang "sinisinok" yung makina mo.. kasi kinakapos ng kuryente.. malamang ignition coils yun. goodluck sir
- Mar 2014
- 901
June 20th, 2016 01:13 AM #40
Planning to buy a second car. Help me choose. Honda accord has 71k mileage for ₱465,000 Nissan...
honda accord 2014 2.4L vs nissan altima 2015
