Results 11 to 20 of 44
- Mar 2012
- 351
April 22nd, 2013 07:04 PM #11
April 24th, 2013 04:03 PM #12
FYI nga pala. Ung 23K na nagastos ko sa Banawe, kasama na towing dun from Las Piñas. Di na kc gumagana tranny kaya no choice ako kundi pa-tow. One more thing, dont use other fluid sa tranny mo. Only use ung CVT Fluid from Honda, wag na wag mo lalagyan ng ATF dahil di un pwede sa tranny natin.
- Aug 2009
- 109
April 27th, 2013 06:00 PM #13Bakit sir wala po ba warranty yung kela mang Mel Casaba? Bakit parang ang bilis po nasira
- May 2013
- 3
May 20th, 2013 11:20 PM #14
- Oct 2010
- 20
May 22nd, 2013 12:19 PM #15Good day tsikot,
i have almost the same problem . But i dont know if i should start a new thread.
2007 1.8 fd
pag naka on ang ac tapos nag brake, bumabagsak idle ko patang mamatayan. I think auto idle and fd at kelangan ireprogram or relearn ang idle?
Dinala k sa casa alabang. Pinaiwan isang araw. Nag diagnostic at advise na papalitan buong computer 30k++. Hindi daw nag aayos ng ng ecu/ecm?
Ano po prob nung akin? Idle lang or iba? Ano pa options ko ? Thank you
May 22nd, 2013 01:02 PM #16
May 22nd, 2013 01:43 PM #17
- 6
May 27th, 2015 12:48 PM #18Mga Sirs, Good day, Ganito rin po problem ko sa accord 95 ko hindi din po maayos yung menor... pinagtingnan ko na sabi nila sira na servo... magkano po kaya ito at saan maganda bumili... thanks
- Jul 2012
- 345
May 28th, 2015 04:50 AM #19sir bka makatulong ako sa inyo. nag palit rin ako ng cvt tranny c/o mel - sobrang happy ako sa ngyari until bigla nag jerk jaz ko kapag mabagal to idle. nag drop rin rpm.. lalo na kapag bukas aircon. so cut the story short, ignition coils ang problema. kinakapos ng kuryente, nag jump at nag misfire.. lalo na kapag bukas aircon ko.
try nyo testing.. while car is on P, locate the ignition coils tapos alisin nyo yung power source one by one, kapag may inalis kayo power source tapos hindi nag react yung makina then that ignition coil is busted! replace ignition coil and spark para mas maganda. yung jazz ko vtec so apat na ignition coils at spark plugs.. ipon ako then pinalitan ko lahat.. ayon zoom zoom ang bilis na ulit with no issues. sana makatulong tong experience ko.
- May 2011
- 227
May 30th, 2015 07:52 AM #20Hi ganyan din nanyayare sa Honda CVR 2003 ko pansin ko pag bukas AC lights radio lahat na.. may vibration at sounds sa makina at dropping rpm sabi ng Tito ko. First sinubukan ko pacheck un compressor at bearing sa aircon shop sabi walang problem daw pacheck ko daw muna sa mekaniko un support niya baka dun daw may problem pero sabi ng Tito ko baka sa idle up may problem kasi daw dropping daw sa 1/1000 rpm kaya parang hirap in making.
What do you think idle ba may problem? Or iba
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
