Page 3 of 3 FirstFirst 123
Results 41 to 53 of 53
    Jan 2011
    #41
    sir, the car is all stock except for the intake which i upgraded to a K&N short ram. the original engine is a 1.5L D15b SOHC, and the car is a 1998 Honda Capa. Pansin ko lang kasi na smooth ung acceleration up to around 80km/hr, tapos biglang parang nahihirapan na ung engine to accelerate any further. so, ask ko lang if baka may sira ung ECU or un talaga ung max ng engine? and kung ano kailangan ko gawin?
    #42
    Quote Originally Posted by je.tansengco View Post
    Have you checked the usual stuff like fuel filter (both the inline and intank) and the fuel pump? Is the ignition timing adjusted to factory setting?
    IS the exhaust smoky or clear?
    Jan 2011
    #43
    the exhaust is pretty normal as far as i can tell. the fuel filter is brand new. the ignition timing is adjusted to factory setting. if i did an ignition timing advance, what will that do to the car performance? also, will a better exhaust system help increase the top speed?
    i have a few theories although i may be wrong since i'm a noob at cars.
    1. exhaust system sucks
    2. fuel pump not applying enough pressure at high speeds
    3. ECU not working properly
    what do you think?
    #44
    what do you think?
    Given it's an old car, have you checked the in-tank fuel filter? Also check if the fuel pump is giving out the right pressure & flow rate. While there, the fuel line between the tank & engine should also be checked if it's clogged with built-up dirt.
    Regarding ignition timing advance, assuming your car is working right, advancing the timing slightly will increase power output. Do it too much, detonation/pinging will happen. To avoid that (while keeping the advanced timing) you will need to use high octane gasoline. Downside, advanced timing will result in increased fuel consumption.
    Jan 2011
    #45
    sir, is the fuel line the same as a fuel rail? and if yes, would aftermarket fuel rails increase the performance if i decide to replace the old one? thanks.
    #46
    No, they are different.
    Changing the stock fuel rail to an aftermarket version without changing the support stuff (fuel pump & fuel pressure regulator) will not give additional performance because the amount of fuel going into the cylinders will be the same.
    An adjustable fuel pressure regulator or bigger fuel injectors will increase the amount of fuel to the cylinders.
    Jan 2011
    #47
    thank you. i've been looking through the forum and can't find a dealer of high pressure fuel injectors. any suggestions? so, this will definitely make the car go faster right? along with proper exhaust?
    #48
    I think you combined what I said.
    Either an adjustable fuel regulator OR a set of bigger fuel injectors.
    BTW, these mods will require a degree of tuning on your engine's ECU so you will definitely need something like a APEXi S-AFC (Air Flow Converter). This device tricks the engine to add more or less fuel by adjusting the signals from the airflow meter. And along with this, you will need some dyno time to tune/adjust the settings properly.
    Do note that these mods will only work IF the engine is working 100% to start with. Given your engine gets your car to barely 100kph indicates that there is something wrong. I strongly suggest visiting a shop to have the source of your problem diagnosed before doing any mods.
    Jan 2011
    #49
    okay thank you for the help. i also did some research and found out that some if not all cars have speed limiters. maybe this is something worth looking into. thank you.
    #50
    Most cars with EFI engines have speed limiters but typical limit would be at least 180 or 185 kph for japanese cars.
    Apr 2009
    #51
    if my car is peaking at 100km/hr and it is an automatic, ano kaya problem ng car? d15b ung engine ...
    Maybe it's because of the automatic transmission.
    Is that the one with VTEC and CVT Japan version?
    Dec 2009
    #52
    Ask ko lang kung ano recommendation niyo for N/A D15 single vtec for a full exhaust that has headers on low,mid at dulo (if may headers na ganun)?
    Magkano aabutin? Gusto ko po ung tahimik lang na tunog na muffler with some bassy sound.
    Apr 2009
    #53
    I think it's worthy to bring this thread back to life.
    Ngayon ko lang ulit nabasa yung mga replies ni GH. Very timely since I'm re-discovering my D15B the second time around.
    Need to keep at pace at 160+ kph with a Toyota 3S-GE (gen 3 on a Corolla Levin AE101 GT-Apex) and Mazda ZL-DE (on a Lynx GSi) at sprint speeds. As these engines have DOHC and displacements higher than mine, I take mine as the handicap, but still I'm damn having a hard time dealing with that Celica engine in particular.
    Currently, the only engine mods I have are very minimal: just adjustable cam gears (set to +6, too advanced eh?) and a "chambered scav". The intake, fuel delivery, cylinder head and block and exhaust manifold are all stock.
    I'm thinking of downsizing the 2" inlet scav to a 1.75" Sankei free-flow muffler (tried it before and it did 160+ easily on Slex) at the expense of annoying cabin noise.
    Is the chambered scav pushing back too much high rpm power? My cam gear too advanced? Need to reset tappets?
    I feel like my previous D15B two years ago is faster than the one I have right now (both on EG sedans).
Upgrades to the D15b SOHC engine?
