Results 1 to 5 of 5
- Jan 2012
- 36
October 9th, 2017 10:12 PM #1Mga bossing, ride ko civic 01 lxi m/t. bakit po ganun tuwing nagpapalit ako ng coolant (drain muna radiator tapos lagay ng bagong coolant) nagkakaproblem ang idle yung halos mamatay, after ilang araw umaayos na. Nakakairita kasi kung laging ganun. Tenchus.
October 9th, 2017 10:16 PM #2
there is an air bubble or hindi na bleed completely? does the reservoir level drop? run the heater if there is one to circulate the coolant sa heater core...
- Aug 2017
- 319
October 11th, 2017 09:51 AM #3
- Feb 2017
- 5
- Dec 2017
- 2
December 18th, 2017 10:58 AM #5Hi Mga Paps,
Good day! Ask ko lang po anu kaya prob sa 95 honda civic esi (P16 valve engine) aircon system ko. bought the car a month ago and have it AC back to service last week. palit po ako compressor, filter at evap valve, palinis condenser, evap at tubings due to black oil contamination.
Working naman po, pero ang prob at a certain time mga 10- mins malamig pa singaw pero after it lasts to 10 or more mins umiinit po ang singaw na inilalabas niya. Sabi ng Mech na napaggawaan ko po, sa timing lang yun. Anu po masasabi ninyo? First graceful car ko po kasi to kaya worried ako. tapos RPM niya when AC is turned on nasa 800 to 1100 fluctuating. magalaw kamay nung RPM. nataas/nababa...
maraming salamat po mga Paps in advance.
i wonder, are the usual published suspension adjustment specifications supposed to be adjusted...
Wheel Alignment
