Results 11 to 20 of 24
- Oct 2005
- 317
January 17th, 2006 12:23 AM #11depende sa tibay ng dibdib mo..... pag-sakay ko ibang tao,like barkada.sagaran!pero pag-family, pasyal pasyal lang....
January 17th, 2006 02:18 AM #12
ung amin hanggang 170 lang nakayanan ko. wala ng kalsada e. hehehe. pero mukhang kakayanin pa ng 180, 4 kami non sa kotse sa may coastal.
January 17th, 2006 08:36 AM #13Originally Posted by vinj
napansin ko lang, *80Km/h my rpm is about 2000, increment of 500 rpm(2500) = 100Km/h and so the trend continues until you hit the redline of 6000+rpm, the result at about 180 give or take a little.
January 17th, 2006 11:53 AM #14
just want to ask, when running at top speed, say at 180-190 kph, were you alone or full of passengers?
may max speed din kasi pag puno na
January 17th, 2006 01:56 PM #15
Alone or with 1 to 2 passengers at the most (with no or minimal luggage) and around 33-35psi on the tires... I never try gunning for unsure speeds on the expressway with a heavy load. ;)
The LXi gearing is tall, hirap siya to run on 60kph at 5th gear pag may sakay (unlike other sedans which can cruise steadily at 60kph on 5th on a flat road).
January 17th, 2006 02:09 PM #16Originally Posted by carlos
Ako. Im alone kaya malakas loob ko pero kung may kasama ako baka hindi ko napaabot yun malamang batok or sapak ang abot ko dun sa pasenger ko.
January 17th, 2006 02:55 PM #17
Hanep ang difference ng speed kung may weight.
Top speed ko sa RS ko mga 207-210 kmh (almost on the rev limiter in 5th gear, super short ang gearing niya, 160 top ng 4th). Kung may ibang tao, mga 200+ pa rin kung isang passenger. Kung kasama ang wife ko, 96 kmh lang ang max niya... 140 kmh kung nakatulog siya. :lol:
January 17th, 2006 03:07 PM #18
2000rpm in 5th gear is identical to the 5th gear in the 626, diba niky? ;)
surprising that honda put that kind of gearing in a 1.5L engine! of course on paper the 626 doesn't have a lot of HP, but it does have a lot of FT-LB
January 17th, 2006 04:20 PM #20
:lol: siyempre, mas masarap pa rin ang highway cruising ng 626. Haay... kung puwede lang ayusin ng brad ko yung registration! Top speed nung car na yun might be 220 if there were a highway long enough, and the cooling system wouldn't conk out!
Cars with 95-125 hp should do at least 175, up to 190 with good gearing and favorable wind conditions. Claims of 200+ for any car with less than 140 hp are unverifiable because many speedos overclock speeds by about 7-10 kmh. Some European 1.6s are geared to go up to 200 km/h, but you'll need a lot of road to get there.
MT cars with 130+ hp (the Lynx RS, 626, Maxima, Accord, Galant, Civic SiR, most V6s, european cars) should be able to get close to 210 kmh (130mph). Many Europeans are geared to go past this but are limited to speeds between 220 and 250. AT Japs, like the Camry, Accord and Cefiro, are limited to around 190-200, to preserve the engine and gearbox. Lower end AT cars have even lower limiters, around 180+/- on 1.6s.
So the slowest is not the 1.3 or 1.5 economy car... it's really the 1.6 ATs.Last edited by niky; January 17th, 2006 at 04:22 PM.
high idle RPM at engine start
