Results 11 to 14 of 14
March 14th, 2009 03:48 AM #11
March 14th, 2009 08:02 AM #12
The "S" is second gear. You will select S when you need more engine power like trying to quickly overtake a slow moving car on the road. This will be more responsive than simply flooring the gas pedal while in "D". Its also used when you might be going down a steep road (engine brake).
The -/+ you are refering to might be the paddle shifts located directly behind the steering wheel. This lets the driver shift a gear up or down without removing his hands from the wheel. On a car like the City, it's just a toy and/or convenience option than anything else. Handy when needing downshift to overtake but not really used much after the novelty of it has worn off.Last edited by ghosthunter; March 14th, 2009 at 08:16 AM.
- Sep 2008
- 1,219
March 14th, 2009 10:41 AM #14
iba iba rin talaga set up ng mga A/T ngayon... ung isa namin ganito lang itsura...
at ganito ang display kapag nasa Park - "P" yung lever.
aside from P ay R, N, & D lang ang choices at alang S or D3,2, 1...
maybe it's because of the manumatic? i guess...
while the other one eh meron D3, 2, 1... which i believe ay for uphill driving; the lower the selection the lower range of gear/s it shifts through...
sensya na sa pics at bukod sa hindi pa nalilinisan ung car ay cel cam lang ang gamit
Xiaomi E-Car
