Results 11 to 16 of 16
September 23rd, 2013 03:52 PM #11
- Sep 2013
- 12
November 20th, 2013 11:52 PM #12buti na lang nabasa ko to.planning to replace timing belt.sir san kayo or kanino mekaniko nagpapagawa to replace timing belt?painstruct n lng po kung saan atska baka may contact no. salamat po
November 20th, 2013 11:57 PM #13
Sir may kilala ako ok gumawa at hindi ka tatagain s presyo.. kaya lang meycauayan.. mang ramon! Lahat ginagawa nila from latero, makina, simpleng susian.. one stop shop..
Sent from my GT-I8552 using Tsikot Car Forums mobile appBeep Beep! School Bus! Beep Beep! School Bus!
- Sep 2013
- 12
- Nov 2013
- 1
November 22nd, 2013 09:42 AM #15just a noob question mga sir.. how would you know na kelangan na palitan ang timing belt? Thanks in advance tsikoters!
- Jan 2008
- 4,726
November 22nd, 2013 10:30 AM #16visual inspection of the belt for signs of wear and tear or based on the manufacturer's recommended replacement interval referring to the number of kilometers as indicated in the car's odometer.
if there are leaks in you front camshaft seals or crankshaft seals, there is a possibility that your timing belt get contaminated by oil. oil can damage belts resulting to premature breakage.
Xiaomi E-Car
