Results 1 to 9 of 9
- Oct 2019
- 10
November 12th, 2019 02:54 PM #1Radiator leaking when car is not using for days. if on engine no leaks
please help me what is the possible solution for this?
the circle on picture (near the petcock) has water leak when the car is not using for days. the water from the reservoir tank is draining.
but if i use the car. it doesnt loose any water. even long drive.
salamat ng marami!!
thank you!
the car is honda civic ESI 92-95 model
- Jan 2008
- 4,726
November 12th, 2019 03:00 PM #2Replace mo yung o-ring nung drain plug. Walang leak when its hot due to the rubber expanding sealing the leak
- Oct 2019
- 10
November 12th, 2019 03:33 PM #3
- Nov 2008
- 641
November 12th, 2019 04:20 PM #4
- Oct 2019
- 10
November 12th, 2019 04:29 PM #5
- Oct 2006
- 6,248
November 12th, 2019 04:55 PM #6Ginawa ko nung nasira O-ring nung Hilander namin at hindi ako makahanp ng kapalit, nilagyan ko ng teflon tape. Problem solved.
- Oct 2019
- 10
November 12th, 2019 05:51 PM #7
November 12th, 2019 06:15 PM #8
- Jan 2008
- 4,726
November 12th, 2019 06:35 PM #9Much better yung teflon as temporary fix... better to replace the o-ring or the plug itself.. be warned though that if the plug is already brittle it can explode leading to massive loss of coolant
Kung walang spare tire, invest on a Inflator kaysa sa sealant. Inflate the flat tire +10 psi than...
Liquid tire sealant
