Results 11 to 14 of 14
September 26th, 2009 06:49 AM #11
September 26th, 2009 07:08 AM #12
this is impossible. why? pre-mixed coolant ngayon ang nasa cooling system ng pajero ko. pero kung hahanapan mo ng putik, none. yung fx namin, tap water lang ang nakalagay, pero yun coolant reservoir niya, puro na putik/latak or kung ano man yan. coolant is somewhat, the "engine oil" ng cooling system natin. and coolant is mixed with distilled water, where wala siyang residues or minerals na nakapaloob. so its impossible magpuputik ang radiator mo using coolant.
so another thing, useless ang coolant pag TAP WATER lang ang gamit mo. if you will be mixing coolant with water, use DISTILLED WATER, or better yet, buy the pre-mixed ones, kagaya ng prestone. at hindi lang yan, mas mura ang 1 gallon ng pre-mixed kesa sa 1 liter ng pure concentrated coolant
- Feb 2009
- 171
October 13th, 2009 04:34 PM #13Follow-up question lang po. Mga ilang liters ang kailangan na premixed coolant sa normal sedans? Mga 2 liters of premixed or 1 liter concentrated colant 1 liter distilled?
October 13th, 2009 04:58 PM #14
high idle RPM at engine start
