Results 11 to 19 of 19
- Apr 2012
- 94
November 16th, 2012 07:53 PM #11tnx mga boss..naliwanagan na rin ako..di ko na ititipid ang lakas ng aircon kc no effect sa gas.tama ba?
ang kulit..hehe
November 16th, 2012 08:17 PM #12
Turn the thermostat to the warmest setting that's comfortable and leave it there.
- Nov 2009
- 1,756
November 16th, 2012 08:50 PM #13Kulit ka nga bro, hehehe.
Anyway, 25-26degrees ang thermostat usual setting, at habang bumababa ang thermostat mas nagiging makonsumo sa gas, mas lumalamig at mas nagwowork ang compressor, meaning more fuel. In reverse, habang tumataas ang thermostat setting (26, 27, 28...), less fuel consumption, pero mas nagiging discomfort ang temperature (mahina ang lamig) dahil less ang work ng compressor.
Pag naiset mo na yung thermostat sa average desired temperature mo, pwede mong palakasin yung fan para sa added ambiance at convinience mo na hindi na maapektuhan ang fuel dahil battery na nagpapagana dun.
Tsikot Member Rank 4
- 2,716
November 16th, 2012 09:43 PM #14in theory, setting the AC blower fan to higher speed will consume more gas because the compressor will have higher duty cycle
higher fan speed means higher rate of heat transfer and the compressor will have to work a little longer to maintain set temperature
however, the difference in fuel consumption will be minimal and will not be easy to determine in typical driving pattern
samakatuwid ... oo, mas malakas ang konsumo sa 2 (kesa sa 1) pero hindi mo mahahalata
November 16th, 2012 09:49 PM #15
I would rather spend on the additional litre of gas and be driving comfortably. Either way I will still be spending money in one form or the other.
November 16th, 2012 11:40 PM #16
A lower blower setting means that the cold air spends more time at the evaporator. This means that your thermostat will trigger more often, cycling the compressor on and off more often. A compressor is like a car... Stopping and starting take more energy than cruising. This is why inverter ACs save electricity... They don't stop completely, just "idle" after they reach their target temperature.
But having stagnant air also means that for the same compressor setting and load, you're getting less cooling, and will need to set the thermostat even lower to compensate.
Using a higher fan setting allows the air to circulate completely. This means lower average cabin temperature for a given thermostat setting, which means less workload on te compressor. This means a more even temperature arpind the cabin, which means you will actually be turning the temperature setting up higher, lessening thermostat workload.... The compressor still cycles, but less frequently. There are less uncomfortable "hot spots", and less of the "frozen fingers, sweaty back" effect I'm sure we've felt at least once.
Yes... the blower itself heats up the air if it's set too high... heat is equal to motion, after all, but if you get the balance right, you can get away with a much higher thermo setting than usual. During the daytime, I sometimes have the thermo up to 26-28 degrees.
The most economical really is no blower, no compressor, windows closed, vents open. But this is typically only comfortable in early mornings or at night on the highway.Last edited by niky; November 16th, 2012 at 11:50 PM.
November 17th, 2012 06:32 AM #17
apatnaput-limang kutsaritang gasolina lang kada araw ang matitipid mo siguro sa kaka-kalikot mo ng aircon controls na yan. kung talagang nagtitipid ka, mag-LRT ka na lang. wala ka pang inaalalang parking fee at huli ng mga naka-unipormeng kulay bughaw, luntian, dilaw at t*e. ay mali, tsokolate pala!
November 17th, 2012 06:34 AM #18
November 17th, 2012 06:37 AM #19
Sa sobrang init at alikabok dito, you won't notice the FC difference between the aircon off and aircon on...
high idle RPM at engine start
