Poor grounding na ang problem nyan... Ayan ang kadalasan problema ng medyo may kalumaan na auto...
What you need to do is clean the battery cables terminal lugs.. Pati yung naka ground sa body... Be sure it is free from rust and dirt, then put an additional ground sa starter... And mag add din ng positive wire fr. Baterry to starter...
Or much better meron na bibile... Grounding kit ata tawag dun?
