Page 1 of 2 12 LastLast
Results 1 to 20 of 29
    Sep 2013
    Hello,
    Nabanggit sakin ng kaofficemate ko na maselan daw pala sa mga fluid ang honda. Nagpapalit daw kasi sila ng power steering fluid sa casa and they were advised to use OEM stuff. Napansin din daw nila ung nung gumamit sila ng ibang brand. Nagkaron daw ng unusual na tunog ung power steering nila. I Just want to confirm kung maselan nga sa mga fluid ang honda cars.
    Parang napansin ko din kasi sa Honda Civic 97 ko nung nagdagdag ako ng power steering fluid parang may nginig nung manibela ko kapag ituturn habang paandar and ililiko. Mumurahing automatic transmission fluid lang kasi pinalagay nung mekaniko ko. pare-pareho lang daw kasi un. Ewan ko nga lang kung un nga ang cause nung nginig.
    Totoo ba na maselan sa fluids and honda cars?
    Thanks!
    kung banasahin mo sa manual ang sabi doon use only genuine honda fluid. pero ako ginamitan ko ng PSF na generic hanggang mabenta ang civic 96 more than 17 yrs na nagamit di naman nagkaproblema sa PS
    Yung cvt fluid maselan.
    CVT and power steering fluid, OEM ang pinaka okay. The rest, pwede aftermarket.
    Sep 2013
    I see. How much ba ung OEM na PS and CVT fluid? Panu idrain ung PS fluid, pede bang ako ung gumawa?
    Clarification lang, ung CVT is for transmission? Sorry baguhan kasi.
    Thanks!
    Jan 2009
    Add also ATF.
    ATF: Honda ATF-Z1 or ATF-DW1 for 2011 and older vehicles. Honda ATF-DW1 only for 2012 and newer.
    CVT: Honda CVT-F only
    PSF: Honda PSF only
    Mar 2012
    wrong post
    Nov 2011
    as per experience parang hindi naman...I used and still using petron's ATF for power steering fluid for 2 years..no problem experienced. Im using prestone for brakes and clutch fluid, no problem experienced. Im using Idemitsu Fully Synth 5w30 (though ito daw talaga oem ng honda), no problem experienced.
    Nov 2006
    Add also ATF.
    PSF: Honda PSF only
    Sir ano grade po ba ng ATF para sa honda civic 1999 A/T.....thanks
    Jul 2011
    Last na nagpapalit ako ng clutch assembly for my Jazz GD, i bought the regular caltex thuban gear oil, after draining nung transmission, the mechanic advised me na ibalik nalang yung nadrain na oem gear oil and ibalik ko nalang sa pinagbilhan ko yung nabili ko thuban, ang labnaw daw ng OEM gear oil, baka gumanit yung shifting ko pag pinalagay ko pa yung thuban. so, pinabalik ko nalang yung nadrain gear oil, marumi nadin, the next day, i visited honda spa and replaced my gear oil with an OEM one.
    for my jazz GD, all fluids from my car, are OEM, except engine oil.
    Jul 2011
    sa brake fluid maselan din?
    CVT fluid lang dapat OEM...based on my experince...I used and still using non OEM from PSF to Gear oil, ATF and coolant to all our honda. Never nagka leak yun PS...
    Just think about this what's so special or difference ng PS ng honda sa ibang brand? Exactly! Wala...
    Yun coolant kasi ng honda OEM diluted na so ilalagay mo na lang.
    eh yun naglagay ako ng gear oil and ATF na royal purple mas smooth pa shifting kesa nun OEM eh
    Yun gen 1 CRV ko before selling it, yun ang experimental car ko for non OEM products pinalitan ko pa nga yun PSF na nabibili sa ace na never heard na brand, never naman nag ka leak...to think it was a very old car.
    *TS, talagang magkakaproblema PS mo, ATF ba naman ilagay mo eh...
    #retzing
    Jul 2011
    #retzing
    may nababasa kasi ako na nakakasira daw ng water pump ng Honda ung non-silicate free coolants.
    kahit ba aftermarket silicate-free long life coolant 5years pa rin change interval ng coolant?
    Quote Originally Posted by s10pao View Post
    Sa totoo lang masisira talaga lahat yan, eventually. Maluluma talaga eh...yeah just do the scheduled interval change ng fluids and I think you'll be ok...again what's so different from honda's water pump from other brand...wala
    I have been asking the same question sa mga proponents ng OEM fluids all the way for honda, lalo na sa PSF, ATF anong special sa honda from other car brand? I still not getting any answer.
    Baklasin natin PS ng honda ng Toyota. I'm sure walang difference yan and yet you can used non OEM sa Toyota...doesn't make sense.
    #retzing
    Mar 2012
    Sir Shadow, di ba mas mahal ang royal purple ATF kesa Honda?
    Quote Originally Posted by maki mi View Post
    Definitely.
    #retzing
    #retzing
    -Sir tanong lang nailagay ko yung ATF sa PS mga 1 week ago na lately ko lang napasin na ATF pala nailagay ko. tapos ngtanong ako sa mekaniko kung ok lang ba yun sabi nya wla naman daw problem. So far wala naman ako nakitang difference smooth naman PS ko.
    Quote Originally Posted by mr_boogey View Post
    Malaki problema. Gago yun Mekaniko mo. Tanong mo kung nasira siya ba magbayad? Mura mura lang ng PSF 1 liter lang siguro kailangan mo para for your system. Palitan mo na
    Posted via Tsikot Mobile App
    #retzing
    Sir thanks, paano po pala mgpalit ng PSF? Kaya ko po ba gawin to?
    Kayang kaya. Hanapin mo sa YouTube.
    #retzing
Maselan ba sa mga fluid ang Honda?
