Page 1 of 4 1234 LastLast
Results 1 to 10 of 49
    Jan 2011
    Hi Guys, I have a problem with my 2006 A/T Honda City..
    These past few weeks, I'm experiencing jerking problems with my car usually when I'm at a full stop or backing up.. After reading threads here in tsikot, my suspicion was it could be the dreaded CVT issue.
    So I went to Honda Kalookan to have my car diagnosed. They said that my control valve, and flywheel needs replacement. They quoted me 35k all in. I backed out because that's too much money that they're asking. I headed to another reputable shop (not CASA anymore) to have it diagnosed.
    After the road test, the mechanic told me not to worry about my CVT because it's apparently not the culprit. He advised to have my throttle body cleaned first as it might solve the issue. I was charged 450 pesos for that.
    A day after having my throttle body cleaned, the jerking worsened. It feels like my engine's gonna die on me.
    Guys please help me cause I'm don't know what to do anymore.. Any inputs would be greatly appreciated..
    May 2012
    may position sensor ba don sa throttle body?
    Aug 2004
    Replace the IACV. If the jerking is worse after throttle body cleaning, then it's not amenable to cleaning anymore.
    Hold off on the flywheel. At best, if the flywheel is really warped, you can have it resurfaced or rebalanced elsewhere. Honda won't do it for you, casa policy (for any manufacturer) is to replace flywheels once they're out of spec.
    Jan 2011
    As for the IACV, how much would that cost me sir? Hope you have an idea..
    As for the flywheel, how will I know if it's warped or something? Can it be checked easily?
    Is this not a CVT issue? I'm anxious that even if I spend money on replacing the IACV and having the flywheel resurfaced, the jerking won't dissappear.
    Feb 2009
    check the obvious and basic first. have an assistant observe the engine/transaxle while you shift to reverse and forward with the brakes applied and the hood open. there is a possibility the north and south engine mount (insulators) are worn or cracked. the age of the car usually have these components fatigued and the rubber dry rotted
    Aug 2004
    You'll know it's the CVT if the shifts are very slow or if engine revs don't seem to match acceleration.
    Engine mounts would be felt as increased vibration at idle, mostly. If the engine feels like it's dying when coming to a stop or shifting into gear, it's most likely IACV.
    Jan 2011
    Noted Sir Niky. Another scenario is when coming from a full stop. The car doesn't move immediately after releasing the brake pedal. There's a slight delay of about 4 seconds before it starts to move again. Before it moves, it sometimes jerk first. What do you think sir?
    Also when cruising, the car decelerates fast once it reaches the 30km/h mark. It feels like someone's stepping on the brake pedals.
    Please help me..
    Jan 2011
    Up.. Please help.. I'm getting desperate..
    Nov 2014
    Quote Originally Posted by mondymondy View Post
    Please help me..
    Sir pa update naman ano naging solution po...sharing experience would definitely help us mga may problema sa CVT....
    Oct 2016
    Quote Originally Posted by Arvin022274 View Post
    update namn po if ano na po naging solution dito.. experiencing the same problem for my honda city 2004..
2006 Honda City A/T - Jerking Engine :( Please help...
