Results 1 to 10 of 12
- Apr 2012
- 94
April 2nd, 2012 12:58 AM #1Mga sir,hingi lng ako sa mga insights and ideas nyo para makatipid sa kunsomo.salamat
April 2nd, 2012 02:55 AM #2
Let's be objective..
Normal fuel consumption of a gasoline-fed compact sedan is around 8-10 km/Liter. Here are some tips that can help you achieve better fuel mileage.
1. OIL CHANGE - 100% Motul H-Tech 100 Plus 5W-30 with Engine Flush.
2. TUNE-UP : Air filter, spark plugs, fuel filter.
3. QUICKLUBE : Change fluids and lubricants.
4. Air-up all four tires to 32 PSI.
5. Remove excess and unnecessary weight. If you can.. fill-up only half a tank at a time.
6. Only use unleaded gasoline. Use fuel injector cleaner additives to clean your fuel line/system.
7. Keep city cruising speed at around 60 kph on third/fourth gear.
8. Drive sensibly. Aggressive driving (speeding, rapid acceleration and braking) wastes fuel.
9. Plan your everyday driving trips. Combining errands into one trip saves you time and money
10. Avoid Excessive Idling. If you will be parking/waiting more than 3 minutes.. KILL THE ENGINE.
Hope that helps!
Kiper
PowerTORQ Motorworks Congressional
https://www.facebook.com/powertorq
- Apr 2012
- 94
April 2nd, 2012 11:57 PM #3Salamat po
Hirit pa ako sir..normal lng ba sa morning or from long hours patay oto,pagstart ko pumapalo sa 1500 ang menor?pag on ko ng aircon,nasa 800-900 na lng.does this mean makakatipid ako kung naka aircon? Salamat mga boss
- Apr 2012
- 94
April 3rd, 2012 08:01 AM #5
OIKIM ganito muna ang gawin mo, pag ka start normal lang na mataas ang irpm/idle mo, then gradually habang tumataas ang tamp ng makina bumababa naman ang rpm nito. then pag normal temp na ang makina dapat between 650-700 rpm lang. then buksan mo ang aircon from 650-700rpm tataass ito sa 850-900 rpm.
- Apr 2012
- 94
April 3rd, 2012 07:36 PM #6Ic..so hindi normal ang menor ko sir..nu po ba remedyo nito?tune uo?salamat pO
- Apr 2009
- 1,902
April 4th, 2012 12:54 AM #7
April 4th, 2012 01:04 AM #8
April 4th, 2012 01:16 AM #9
Honestly, just dont press hard on the gas pedal too much and avoid accelerating then braking like those jeeps na kala mo kailangan maunahan ang lahat and then biglang stop kasi may pumara.
April 4th, 2012 09:32 AM #10
*oikim, tama sabi ni sir kiper, it's perfectly normal from cold start then when it reach the normal operating temp, it will go down to 650-800 (w/ AC). mine pala is '97 Civic VTi A/T. Ginagawa ko para mas makatipid pa... pagkastart, slowly gapang na ako forward w/out accelerating muna... wala pa naman ako sa main street & wala naman car sa likod ko. ours is not diesel na need talaga painitin pa (para sa mga old diesel engine ata ang style na'to)... oh btw, when turning off the engine, wag mo na i-rev pa ng ilang beses, sayang sa gas... habang tumatakbo ka umiikot na ang oil kaya no need na gawin yan, time pa nina lolo yang style na yan old skul ika nga. ;)
Xiaomi E-Car
