mga bossing,, pansin ko lang kasi medyo tagilid ang gulong ko sa likod, ung upper part leaning inside,(papasok sa loob).. saan kaya problema nun?.. kasi napupudpud ung tyre ko sa lood,, di pantay,, tnx
Yapoy is right, some car have adjustable camber so its alot easier if you can explain in more detail about your car.
Anyway, obviously this is the camber angle causing this. It's 100 % not the strut. I would find a reputable shop where you live that does free estimates on these sorts of things and take advantage of that. Most likely, it's a bent control arm.
If the car was lowered without installing a camber kit, that will put the camber into the wrong geometry. Either that or the rear springs are getting saggy.
