Results 1 to 10 of 57
Threaded View
- Apr 2009
- 1,902
March 18th, 2010 11:00 AM #25Replacement thermostat for d15b is P600.00 sa Alabang Parts Center. Most likely ganun din dapat sa ibang shops. Ang OEM original yata is around P1200.00...
Pwede niyo naman itakbo yung auto kahit walang thermostat, if ever yun nga ang problema, para lang maialis na dun sa shop. If everything is working out fine at wala yung thermostat dapat hindi aakyat sa normal yung temperature niyo, meaning mas mababa dapat and temp reading meaning malamig ang makina to least likely overheat (I did that before prior to replacing it, although hindi efficient ang makina pag wala nito, but it should take you farther to a better shop) ...
Natunaw yung unang cylinder head gasket mo kasi nagoverheat ulit eh. It's metal warping because of excessive heat. Hanggat hindi makita yung source of overheating matutunaw at matutunaw ulit yan.Last edited by isa1023; March 18th, 2010 at 11:03 AM.
Ford kasi... it needs a lot of TLC. ;) Kidding aside, I don't know if other turbo vehicles have...
0dometer problem
