Results 1 to 5 of 5
- Mar 2009
- 48
August 20th, 2009 05:30 PM #1can i ask for help in replacing the stock muffler of my civic vti 05, a/t. i plan to upgrade it. just a little modification, will the hp of the car would also be affected? Can you recommend for reliable shops.. im in between makati and manila. near La Salle...(how much would it cost me for the upgrading/replacement) thank you...
August 20th, 2009 05:50 PM #2
Replacing a stock muffler with an aftermarket will not affect the HP. of your car . It also depend on what muffler to choose the difference is the sound if you want loud or not depend on the design of the muffler inside.
- Mar 2009
- 48
August 26th, 2009 05:15 PM #4salamat sa mga reply sir. how much should i prepare if i choose the jasma type? any other mufflers that are good? usually sa mga car shops you can buy. i would like to buy sana then kasama na yung paglalagay. instead of buying ing blade or concorde.
August 26th, 2009 07:05 PM #5
JASMA spec mufflers should set you back around 6-8k (2nd hand), depending on condition... You can have it installed at your suking muffler shop for mga 500 siguro. Kadalasan, surplus shops don't do muffler installs.
high idle RPM at engine start
