Results 21 to 30 of 33
- Apr 2008
- 99
- Apr 2008
- 11
April 29th, 2008 01:11 AM #22pareho kami ng problem ni tonyboy...
may question lang na din po ako.
1.) ang throttle po ba ung nasa top ng engine area. Yung kulay silver na dun nakakabit ung pinipintod para magbigay ng gas? Pwede po ba sa general mechanic pacleaning ito?
2.) Tinatanggap pa din po ba ng Honda Casa ang kotse na napa-maintain na sa other auto service centers? May naririnig kase ako dati na Hindi na tinatanggap ng casa ang mga cars na na-maintain na ng ibang service centers. Balalk ko sana dalhin sa casa para sa valve tappets tuning
April 29th, 2008 12:44 PM #23
They'll accept them, but casa service is expensive, so unless you're having them read engine codes, you can just as well take them to a good outside garage.
April 29th, 2008 05:03 PM #24
same problem tayo TONYBOY, just solved that last friday just replaced your iacv, located sa likod ng TB, color black with elect connector secured with 2 bolts, punta ka sa evangelista dami doon surplus JDM cost 1,500pesos only kasama kabit, pero dami nagtitinda up to 2500pesos wag ka paloloko. from edsa turn right sa jollibee, after ng bridge merong mga tindahan ng surplus sa right side doon ako nakabili. try mo.
- Apr 2008
- 11
April 29th, 2008 10:57 PM #25ang cleaning po ba ng idle air, fast idle and tb electrical o mechanical job?
Gusto ko lase malaman para alam ko kung kanino dadalahin na mekaniko. Tska magkano kaya aabutin ang cleaning ng 3 parts na yan? thanks
April 29th, 2008 11:35 PM #26
cleaning ng intake manifold , throttle body and other sensors babaklasin ang mga ito at gagamitan ng solvent for cleaning what type of solvent di ko alam, you could try speedyfix sa mandaluyong or hongly sa paranaque.
- Apr 2008
- 99
April 30th, 2008 03:12 PM #27Mukang tama ka sir orly, I did a little experiment the other day. Disconnected the TPS then after depressing the gas walang nang biglang drop ng RPM even while the A/C is on. Kapag normal load naman my idle is steady, pag may A/C lang nagloloko.
Is possible ba na my TPS is not working properly but walang CEL? Possible din kaya na flow ng kuryente ang issue kaya may sudden drop ang RPM?
- Apr 2008
- 99
April 30th, 2008 03:20 PM #28
May 20th, 2008 12:50 PM #29
sir ano na po update sa civic nyo? i have a similar problem.. pag naka on ung AC bagsak rpm halos namamatay ung makina... minsan naman nanginginig pa... napatinging ako sa dalawang shops sabi saken servo daw kailangan linisin..
- Jan 2010
- 50
January 28th, 2010 11:31 AM #30to all tsikoters, i would like to share may problem regarding my civic lxi 99 with the same idle problem especially when aircon is on.I have check & clean my servo but the same problem still. I need your help.
Pag inaangat ko yung tension wire ng
spurplug 1, nagrereact ang makina,dinig mong nahihirapan
same with spurplug 3 and 4
but not with spurplug 2. Kung iaangat ko spurplug 2, parang wala lang.
Ive checked my HTW and ok naman.Replaced new spurplug.
Is it possible na yung distributor ko problema kasi wala siyang naiidistribute sa spurplug 2 ko?
Anybody experienced thesame thing?
Please help.
Thanks in advance
Xiaomi E-Car
