Results 21 to 30 of 67
- Sep 2007
- 110
April 27th, 2011 10:12 PM #22may leak yan sir for sure. tingnan nyo ang upper part ng rad kung may basa pati ang upper rad hose. kapa-in po ninyo yung lower part ng rad at hose kung may basa rin. jack the car para di kayo mahirapan. tingnan ang mga bypass hose kung may basa malapit sa thermostat housing. pati yung mga nasa iacv na maliliit na hose. check it early in the morning para malamig ang makina at para visible talaga mga leak. hth
- Jan 2011
- 262
April 28th, 2011 02:00 AM #23I always check it every morning.. I don't see any leaks bro.. Kinapa ko mga hoses and they don't seem to be wet..
Do you guys now any reputable radiator shops? Ayoko sana pmunta sa mga kanto kanto radiator shops coz they might point something is broken but in reality it isn't.
How much is the labor for flushing the radiator? How manly liters of distilled water should I bring and how many bottles of coolant?
As of now I'm using the Petron Coolant.
Do you think I should already bring it to a radiator shop? D naman po ako nag ooverheat eh.. I'm on a tight budget rin kasi hehe..!!
Thanks guys!!
April 28th, 2011 02:38 AM #24
- Jan 2011
- 262
April 28th, 2011 11:55 AM #25
- Jan 2011
- 262
April 28th, 2011 12:11 PM #26
- Jun 2010
- 321
April 28th, 2011 12:55 PM #27
- Jan 2011
- 262
April 28th, 2011 01:40 PM #28I forgot to mention what happened yesterday.
In the morning, I refilled my reservoir up to the MAX indicator and the radiator itself. I even spilled some coolant outside the radiator so I think punong puno na yun hehe..!
I drove from our place to the office. Distance was 6 - 7km. After turning the engine off, I popped up the hood to check the reservoir. It lost a bit of coolant, mas mababa na siya sa MAX level.
Then some gimik...
Drove someone home, kinda traffic.. some bumper to bumper instances.. temp gauge went a bit above midway pero hindi naman abot 3/4, then back to mid.
This morning, I checked the reservoir.. Ubos ang laman.. 40 kilometers ang tinakbo ko.
What do you think guys? I hope my explanation is detailed enough
- Apr 2009
- 1,902
April 28th, 2011 01:56 PM #29Check your oil dipstick or oil cap for "pinkish milo"!
If you excessively emit white smoke, chances are it's a worn out cylinder head gasket!
Your coolant mixes with the oil, gets burned in the chamber, hence the white smoke!
- Jan 2011
- 262
April 28th, 2011 04:39 PM #30
Haven't checked the dipstick again, but last time I check, it's dark brown in color..
Haven't checked if I emit white smoke out of the exhaust recently but last time I checked, it emits colorless smoke.. everything looks normal naman.. Usually kasi after I start my engine, drive away na.. hehe.. BTW, does the white smoke come out from the start? or do I have to use my car for a bit?
Will check both of this tomorrow.. Thanks!!
