Results 1 to 10 of 16
- Apr 2009
- 1,902
August 7th, 2009 05:06 AM #1so here's your case:
ph16 (a non-vtec) port and polished head
stock IHE
4 speed matic
*for intake, cheapest best value is simota tube with knn cone-type (around 4.5k sa banawe, tabi ng autocircuit)
*very subtle to no feel on power pag intake lang on stock headers and muffs, lalo na po sa matic
*modify headers and exhaust? depends up to what extent are you willing to up them.
are you willing to remove the resonator? increase mid/downpipes diameters? go free-flow muffs and compromise added noise?
less restrictive exhaust > more hp on high rpm can be felt = more low-end torque you compromise to lose
more low-end torque you lose > mas matakaw sa gas (i suppose hindi ka naman magd-drag, so why need high-end power that often diba?)
* want silent, free-flow muffs?
ask gh. he has one, customized.
* better breathing = more power?
not right away, kahit naka port n polish ka pa.
in this case, if you bolt on the knn, you only have more air in. if you run on stock fuel maps, kahit nireset mo pa yung ecu mo after the install, you wont feel much difference.
I have the short ram in my d15b. even after the ecu reset, subtle pa rin ang feel of increased power, if any. (runs on stock headers and free-flow muffs)
* keep stock H-E and go short ram?
in my case, it's short ram > d15b m/t > stock 421 headers and midpipes (and anything in between) > free-flow muffs
result = I still have lots of useful low-end and mid-end power. matipid sa gas. medyo hirap lang si engine sa exhaust pag near redline na on high, but still it reaches and can sustain 180+ kph
* ball park figs?
KNN cone-type with simota tube = P4500
421 crush bent headers (sa fremuff) = P3800
421 mandrelbent headers (sa mufflerland) = P5900 yung aluminized (P13500 yung stainless)
muffs with optional silencer (apex-i copy sa fremuff) = P4500
Sir, advise lang, come to think of this:
Honda sohcs yield relatively high outputs using vtec wildcams on sustained high rpms.
You don't have both. Why?
- No wildcams, kasi non-vtec yang ph16 stock engine
- No sustained high rpms (expect on top gear), kasi it's matic (w/o manual override)
You feel the power gains from IHE mods most especially on mid to high rpms.
Im no honda expert, just my two-cents worth po. Hope it helps
- Apr 2009
- 1,902
August 7th, 2009 06:05 AM #2Suggest you save more and get a d15b with manual transmission.
You can get one for as low as 30K, i think.
stock d15bs can yield higher outputs compared to stock, pnp'd ph16s, because of the vtec.
you get an engine with better fuel economy with higher power on your beck as compared to your stock.
- Aug 2005
- 205
August 7th, 2009 12:57 PM #3want real power?
1. aem or iceman intake with knn filter - 12k
2. full exhaust 2" piping mandrel bent at mufflerland (aluminized pipe with reso) - 12k
3. jasma muffler - 6k
4. apexi safc - 6k
5. wide band tuning - 3k
6. tranny cooler - 5k
this upgrades will give you real hp gains that you will feel.
total cost: 44k
db15 transplant:
engine/m/t tranny package - 28k
install - 5k
a/t to m/t conversion - 8k
lto registration - 4k
total - 45K
conclusion: go for a d15b m/t transplant. it will cost you almost just the same with more power and more potential.
August 7th, 2009 02:08 PM #4
AT transmission.. oks lang IHE diyan.. increase HP ..
Had mine done at SMT in Mascardo, makati. 8969243 tell them nirefer kita.
Headers 4.5k
-ito una ko pinagawa sa Exalta ko matic yun. ramdam ko agad yung gains.
Intake
- depende sa iyo.kung madalas ka malulusong sa ulan or madadaanan na baha hindi advisable na mag CAI ka. Short ram lang pwede na
Exhaust
- mas ok yung chambered muffler.
Midpipe
- ito madalas nagkakamali. 2 3/8 lang wag na sobra dito ayus yung gains. di masyado malaki ang kelangan mo para di mabawasan yung gains.
addtl : thermal wrap
- Aug 2005
- 205
August 7th, 2009 05:25 PM #5i/h/e on hondas without tuning might increase your hp. but again, it moves your torque curve higher in the rev range resulting to poor fuel consumption. if your the type that gives a go on every chace you get, go for the mods and be happy with the sound it gives. but, if you use your car for daily drive, i will suggest not touching your engine at all.
you can even test 2 a/t esi, 1 stock, 1 with i/h/e on a drag race. i guarantee you that from standstill, the stock car will win.
August 8th, 2009 07:53 PM #6
August 9th, 2009 12:20 PM #7
You get more torque at the lower rpm band with a chambered muffler. Freeflows only free up more power at the higher rpm range.
August 9th, 2009 12:56 PM #8
Okay lang sa honda Esi A/T ang I/H/E. Mods. Additional horsepower . Good for daily driving. AEM wai air intake , Aem Dry flow filter , RSR Muffler. 4-2-1 header.
- May 2007
- 104
August 9th, 2009 11:18 PM #10medyo mataas pala kung real power... hehe... and i dont want to transform at to mt. una may kamahalan and second its complicated. maraming salamat sa advice sir, it really helps a lot. at least alam ko na yng price range kng real power tlga ang gs2 ko mkuha. hehe. what would you advise if i need slight (saktong) power gain lang and yet mura... based from the persons na sumagot ng thread,,, do you agree short ram and free flow muffler will get me at least slight engine performance increase? if this will work, eto na lang mod na gagawin ko. and one last thing, if nag palit nko intake does my ecu needs to be reset para equal yung bitaw ng gas sa fuel injection?
just did a quick search... BYD e6 - Wikipedia Yung 1st Gen BYD e6 pala was released in 2009...
China cars
