Results 1 to 10 of 33
- Jan 2010
- 50
January 29th, 2010 10:56 PM #1I have done some minor repairs with my idle problem.
Did some cleaning with my servo,change oil,change all my spurplugs and patope.
Idea:
with my new 4 spurplugs,
kung tatanggalin ko yung high tension wire sa
spurplug #1, nanginginig engine ramdam mo epekto
spurplug #2, nanginginig engine ramdam mo epekto
spurplug #3, walang epekto
spurplug #4, nanginginig engine ramdam mo epekto
looks fine naman yung car,
malakas pa din arangkada,
wala usok
walang kakaibang tunog sa engine
walang basa sa spurplug(yung pinalitan ko)
ang sabi nung isa sa mekaniko ng shell sa alabang-zapote road,
top overhaul daw? ang pangit lang wala man lng siyang ginawa to check para magkaroon siya ng idea. basta tinignan lang yung sinabi ko na kung inaangat yung HTW ng spurplug #3 e walang epekto sa engine
anyone experienced the same thing?
Please help...
Thnks in advance and more power to tsikot.com
- Jan 2010
- 50
January 30th, 2010 12:14 AM #2dagdag ko lang po.
the car is manual.
tapos sa cold engine start.matatas idle ko mga 1.3 which is i think normal.
then pag maiinit na mga .8 na lng idle nya
kung on aircon mga .5 to .6 na lng idle kaya nanginginig na engine.
wala namang lumalabas na warning sa panel ng car.
THE AUTO SPECIALIST
- Mar 2006
- 607
January 30th, 2010 12:56 AM #3kailangan dyan scanner to read if the ecu is receiving an a/c compressor signal.good luck
- Jan 2010
- 50
January 30th, 2010 03:42 PM #4im planning to have a compression test. what do you think? thanks sa po reply.
- Jan 2010
- 50
January 30th, 2010 03:47 PM #5bambino i dont think may prob sa dun kasi gumagana pa automatic ng aircon.besides my aircon was repaired by ceejay 2 months ago.thanks pala sa ceejay las pinas.I am very much contented with your service.Actually dina ako bumalik for your free checkup after 1week.
What about the problem with my spurplug. Any idea? Ano ba possible cause na di gagana function ng nito.
again thanks po sa nagreply.
- Jun 2009
- 325
February 1st, 2010 04:40 PM #6
February 1st, 2010 05:52 PM #7
Check mo sparkplug wire mo baka iyong #3 na wire may depresiya na . Pagpalitin mo ng wire para malaman mo kung ganoon pa rin . Kung tuyo naman at maganda sunog huwag kang magalalala. Hindi kailangan ng top overhaul diyan . Iyong tope naman depende rin sa gasolina gamit mo at pa check mo engine timing mo kung tama.
- May 2007
- 104
February 1st, 2010 05:58 PM #8nausbukan mo bang ilipat yung spark plug 1, 2 or 4 dun sa spark plug 3? pwede din kasing defective yung spark plug 3. kahit na bago pa yan pwede ring defective, para sure lang lipat mo yung ayus na proven na ayus na spark plug sa no 3 para ma sure mo na ang cylinder no 3 talaga ang may problema.
pag tapos nito at talagang wala pa rin nangyayari, pa compression test mo na nga.
- May 2007
- 104
February 1st, 2010 06:02 PM #9pwede ring hi ten wire ang problema as speed unlimited mentioned. pwede ring kuryente, distributor, kelangan ma diagnose ng maigi using elimination process... pa check mo din para kuryente from the distributor, pag ok dun, saka mo na pa compression test.
Before the power run both filters are already primed so pre-fill should no longer be an issue, but...
Thick (20W-50) vs Thin (5W-20) Engine Oil Tested
