Page 1 of 2 12 LastLast
Results 1 to 20 of 33
    Jan 2010
    I have done some minor repairs with my idle problem.
    Did some cleaning with my servo,change oil,change all my spurplugs and patope.
    Idea:
    with my new 4 spurplugs,
    kung tatanggalin ko yung high tension wire sa
    spurplug #1, nanginginig engine ramdam mo epekto
    spurplug #2, nanginginig engine ramdam mo epekto
    spurplug #3, walang epekto
    spurplug #4, nanginginig engine ramdam mo epekto
    looks fine naman yung car,
    malakas pa din arangkada,
    wala usok
    walang kakaibang tunog sa engine
    walang basa sa spurplug(yung pinalitan ko)
    ang sabi nung isa sa mekaniko ng shell sa alabang-zapote road,
    top overhaul daw? ang pangit lang wala man lng siyang ginawa to check para magkaroon siya ng idea. basta tinignan lang yung sinabi ko na kung inaangat yung HTW ng spurplug #3 e walang epekto sa engine
    anyone experienced the same thing?
    Please help...
    Thnks in advance and more power to tsikot.com
    Jan 2010
    dagdag ko lang po.
    the car is manual.
    tapos sa cold engine start.matatas idle ko mga 1.3 which is i think normal.
    then pag maiinit na mga .8 na lng idle nya
    kung on aircon mga .5 to .6 na lng idle kaya nanginginig na engine.
    wala namang lumalabas na warning sa panel ng car.
    kailangan dyan scanner to read if the ecu is receiving an a/c compressor signal.good luck
    Jan 2010
    im planning to have a compression test. what do you think? thanks sa po reply.
    Jan 2010
    bambino i dont think may prob sa dun kasi gumagana pa automatic ng aircon.besides my aircon was repaired by ceejay 2 months ago.thanks pala sa ceejay las pinas.I am very much contented with your service.Actually dina ako bumalik for your free checkup after 1week.
    What about the problem with my spurplug. Any idea? Ano ba possible cause na di gagana function ng nito.
    again thanks po sa nagreply.
    Jun 2009
    Quote Originally Posted by JunBargas14 View Post
    Much better to have it scanned to see if there are any trouble codes and undergo compression test.
    Check mo sparkplug wire mo baka iyong #3 na wire may depresiya na . Pagpalitin mo ng wire para malaman mo kung ganoon pa rin . Kung tuyo naman at maganda sunog huwag kang magalalala. Hindi kailangan ng top overhaul diyan . Iyong tope naman depende rin sa gasolina gamit mo at pa check mo engine timing mo kung tama.
    May 2007
    nausbukan mo bang ilipat yung spark plug 1, 2 or 4 dun sa spark plug 3? pwede din kasing defective yung spark plug 3. kahit na bago pa yan pwede ring defective, para sure lang lipat mo yung ayus na proven na ayus na spark plug sa no 3 para ma sure mo na ang cylinder no 3 talaga ang may problema.
    pag tapos nito at talagang wala pa rin nangyayari, pa compression test mo na nga.
    May 2007
    pwede ring hi ten wire ang problema as speed unlimited mentioned. pwede ring kuryente, distributor, kelangan ma diagnose ng maigi using elimination process... pa check mo din para kuryente from the distributor, pag ok dun, saka mo na pa compression test.
    Sep 2009
    try mo palitan yung spark plug no.3..
    baka need na palitan.
    Jan 2010
    salamat po sa mga replies. i appreaciate it much. nacheck ko na mga high tension wires.pinagpapalit ko and im sure wala problema HTW.sa spurplug #3 naman im very much sure na wala ding problema. Ang suspetsa ko lang e distributor. Di naman sunog yung spurplug #3. What do you think wala bang possibilty for top overhaul? Ano ba basis ko kung need top overhaul yung car?
    Jan 2010
    dadag ko lng po.ano ba symptoms na pwde ko makita just incase distributor ang problema.
    Kung distributor problema ang symptoms niyan hindi magbibigay ng kuryente kung contact point gawin mo on mo ignition switch tapos kumuha ka ng screw driver at itapat mo sa contact point at itaas mo ng konti dapat may spark ng kuryente kung wala kahit ano gawin mo hindi aandar sasakyan mo. Umaandar naman sasakyan mo .Gawin mo habang umaadar hugutin mo ang high tension wire spark plug no.3 at itapat mo sa spark plug pag walang spark may problema sa supply ng kuryente ang distributor . Pa check mo na lang spark plug no .3 marami kasi ngayon labas na fake ano bang brand ng spark plug gamit mo . Nangyari na rin sa akin iyan at walang spark pagtinapat ang HTW. Advice ko lang sa iyo sa mga symptoms ng makina mo na ibinigay mo hindi kailangan ng top overhaul maliban na lang kung basa ng langis ang mga spark plug mo at kumakain na ng langis at mausok at basa ng langis ang tip ng tambutso.. Sabi mo tuyo lahat.
    Jan 2010
    update ko lng po just in case may makaencounter same problem.
    pinakita ko sa isang mekaniko sa las pinas.
    check spurplug - all ok
    check HTW - all ok
    check distributor - all ok malakas naman lahat koryente pati spurplug #3
    ito suggestion ng mechanic:
    may singaw sure daw yun based sa experience nya
    ang simtomas daw ng may singaw sa balbula. sa idle tapos lalakas daw kain ng gas.
    tama naman kasi napansin ko lumakas kain ng gas nung car.
    wala naman ng ibang pwdeng may problema?
    kung ok ang spurplug,HTW,distributor,ok naman servo
    ang sabi nya topoverhaul daw.
    7,500 labor
    12,000 pamachineshop
    any comment po?
    tama lang ba price nya?
    especially sa machineshop bakit ang mahal
    5 days daw.
    to all replies thanks
    *JunBargas14
    Bro sa tingin ko mahal ang quote sayo kung top overhaul lang ang gagawin. Dati meron ako '96 Civic VTi at kung may problema sa makina o suspension sa Sprint sa Banawe ko dinadala, magagaling mekaniko nila dun. Although hindi pa ako nagpapa top overhaul, ang friend ko na may '95 Corolla XE nagastos nya P13,000 lang...top overhaul (parts + labor).
    Suggest ko bisitahin mo Sprint, libre naman ipatingin. Kung galing ka Quiapo via Quezon Av. kumanan ka sa Banawe. Yung unang kanto sa kanan dun sila located. Early morning ka magpunta para wala pa masyado customers at madami nagpapagawa dun. Good luck.
    +1 sa sprint. mura talaga dun pag top overhaul. haba lang pila. 12t labor and parts na sa civic esi namin dati compared sa casa na 40T
    Jan 2010
    thnaks sa suggestion bro. coding ko bukas e so cguro sa sabado drop ako dun
    Jan 2010
    jaymd bro yung ginastos mo sa esi mo na 12 taw kasaba ba dun yung pamachineshop? mga bros salamat sa replies
    Jan 2010
    just an update to my idle problem
    1. pinahasa ko balbula, thnaks God walang pinamachine shop
    2.suggest ng mechanic palitan na piston ring since medyo kalog na so dukot lang to change piston rings.
    3. after that ayun di pa rin gumana yung sparplug #3 ko.
    4. pinalitan injector then oks na
    5. ang lakas na nung car.swabe oks na oks na
    ang problema na lng idle nya kung nakaneutral.
    masyado matatas 1500, kung ion mo aircon bababa siya ng 1000
    nacheck na servo pero ganun pa rin
    ang sabi ng mechanic
    computer box daw?
    any comments mga sirs...
    Jan 2010
    is it possible that there is something wrong with my computerbox,where can i find this thing. any shops you can recommend to fix this thing...
Idle problem with my civic lxi 99. TULONG...
