Results 1 to 17 of 17
    My City 2008 MT suddenly encountered EPS light on the dash. Steering is also heavy. Anyone encountered this and how to solve it?Help is very much appreciated.
    Posted via Tsikot Mobile App
    Jul 2014
    Sir Try mo pa check ang EPS Sensor.
    Jan 2008
    Pa scan mo to check the fault. Possible fault source EPS module, motor, torque sensor or just a busted fuse
    I m going to Honda Alabang on Thursday for diagnosis. I hope parts are available and not too expensive. Thanks to those who replied.
    Sir Nizm paki update nyo kami kung ano findings. Yung sakin 08 idsi matic may kalampag pag nilalaro mo manibela (while parked) kaya pag uneven yung kalsada akala mo sira na ang mga pangilalim pero hindi naman. Sabi ng mga underchassis mechanics yun daw steering motor na daw maluwag na yung bushing, ang mahirap dito palit steering motor assembly na daw. No idea pa kung magkano pero sigurado ako mapapamura ako sa mahal.
    Oct 2013
    Quote Originally Posted by nizm127 View Post
    that is the worst thing you will possibly do...
    punta ka sa shell customer cradle, sa harap ng perpetual help hospital
    Meron ba kayo alam na mas nearer like Sucat? Salamat
    Jun 2005
    diba sa sucat si hongly?
    ^ yes. tapat ng wilcon
    you can try pitworkz hongly nga din. ok iyan sila gumawa at bihasa din sila sa mga honda
    Quote Originally Posted by Stigg ma View Post
    hahahaha! agree with this one.
    Try ko sa Thursday. I hope they have engine error code analyzer to eliminate guest work :-)
    Hi Sir meron ba sila pang check ng DTC or engine diagnostic code?
    ^ i'm not sure but i think they have. ang pinagawa ko kasi dati ay replacement ng fuel filter sa fd ko kaya hindi na kinailangan gamitan ng scanner. pero recommended iyan sila sa honda club at team fd kaya dinadayo pa iyong hongly kaya dapat agahan mo doon
    another shop i can recommend along sucat ave is d & r fast repair (look for the owner, danny, who is an ex-tech of honda). ayan sigurado ako may obd2 scanner kasi ginamitan last year iyong fd ko niyan nuong nagka-problema ako sa ride ko. the shop is beside mercury drugstore and sm hypermart
    I was able to find Hongly, he thinks solution is replacement of EPS module which is 24k from Honda dealer. I asked him if he can reset via documentation i have downloaded from the internet, but he doesnt know how nevertherless see attached doc. Any ideas. TIA.
    Attached Files Attached Files
    Dec 2008
    Sir, try mo muna i-disconnect ung battery for 15 mins. Baka marereset. naexperience ko na dati ito on a '06 fd. Bigla eps warning sa dash. Sobrang tigas ng steering. Mas matigas pa sa manual steering. May nakapagsabi na try to reset by disconnecting the battery and it works. After 3 months naulit ung problem pero di na nakuha sa battery reset. No choice but have it checked dito sa honda batangas. Para sa akin ok ung customer service nila dito. After scanning, dami lumabas na error. Tested all the eps component and all are good and still ang dami error. Kinalkal nila ung wiring harness at dun nakita problema. May mga talop na ung mga wire kasi parang may ngatngat ng ipis yata o langgam. Inayos na lang ung mga wire ang naging ok na. Cost me 1k for the labor. Buti na lang. Hehe.
    Dec 2008
    Quote Originally Posted by Wishing View Post
    Sir, Around 12k yata ang eps motor.
    Quote Originally Posted by odie42 View Post
    Sir odie42 saan po kayo nag pa quote ng motor?
City 2008 EPS problem
