Results 1 to 3 of 3
    Nov 2014
    Since this is an old model, do you still recommend I buy the power steering fluid from Honda? Or the ones they sell at Shell is ok? If I buy from Shell for example, will it be harmful? Thanks!
    Nov 2007
    Quote Originally Posted by go-to-guy View Post
    We have the same ride, I still use Honda oem fluid, but if you intend to switch, use a fluid that has the same specs as the oem, there is an existing thread here regarding Honda fluids you may want to check it out. hth.
    Oct 2009
    i buy for the local market steering fluid,i use 2 years dati nga atf lang..may nag sabi steering fluyid daw ilagay ko ayun ok naman hanggang ngayon wala pang leak sa mga hose.at rack n pinion
2000 Civic VTi power steering fluid
