Results 31 to 40 of 53
April 28th, 2011 07:31 PM #31
Well the new Civic (9th gen) is essentially an FD that received a major facelift. Even the engine and transmission are the same medyo na tuned up lang yung bagong R18 for the 9th gen...
- Dec 2007
- 42
April 28th, 2011 08:40 PM #32don't forget pag gusto mo FD meron ako benta some OEM mods nakalagay
na siya cruise control na lang kulang
April 28th, 2011 08:49 PM #33
Malakas parehas engine nila kaso mas mabigat ang FD kaya di ubra sa SIR.
Classic ang SIR...if you have the money, keep it...if not then get the FD (yun daw ang next SIR eh hehe)
April 29th, 2011 10:12 PM #34
I rarely see a well-maintained SiR engine plying the roads. Either these have been modified at one point, or revved excessively causing wear and tear. Maintaining and tuning an SiR will prove more expensive in the long run.
Not sure about the SiR being faster than the 1.8 FD. I've road raced a few SiRs with my 1.8 FD M/T (stock engine), and I haven't encountered any SiR that was faster. Do not race on the streets, I am a bad example.
April 30th, 2011 12:25 AM #35
ill stick with the SiR. keep it stock and proper maintenance lang panalo na yung oto.
- May 2011
- 8
May 17th, 2011 02:18 AM #36SIR is a lot better than fDs available here in the PH in terms of speed and performance...to the tS, retain yours
May 17th, 2011 05:46 PM #38
The SiR is faster than the FD in a straight line or a drag-race, but the FD's 1.8 has a good amount of torque and the top end is pretty decent.
The FD also has more stable handling, a stiffer body shell (which makes a big difference on the race track), faster steering and a better, bigger interior with nicer plastics.
But... the SiR is very collectible. If it were mine, I'd suggest keeping the engine mostly stock. At most, put a panel filter in, upgrade to a chipped P08 computer box and go for Type R cams. Then work on stiffening up the old suspension and upgrading the brakes. But that's it. Keep it "sleeper".
A riced-out SiR looks like a badly modified LXi. A clean SiR, on the other hand, turns heads.
- Jun 2012
- 17
July 6th, 2012 03:07 PM #39
- Apr 2009
- 1,902
July 6th, 2012 04:41 PM #40
i had my original spare mag stolen, years ago. i had since installed a cheap bicycle lock, and no...
