Results 1 to 5 of 5
    Baka refrigerant leak. That is dangerous.
    Refrigerant Poisoning: Symptoms, Treatments & Prevention
    Apr 2018
    nag leak test naman sila boss tyaka pinalitan ng buo . wala padin
    Dec 2017
    Quote Originally Posted by talabastardo1 View Post
    It could be that somewhere along the line before the evaporator is the leak. From what I've observed, they do leak test from connections only. That is, the connections from both ends of your evaporator when they replaced it. You can ask them to evacuate the refrigerant and do another leak test. This time, ask them to use a chemical (I can't remember the name) that will be pumped in the system. The leak should be visible with UV light.
    If something went wrong with your compressor before, it could have caused clogging the expansion valve which can​ trigger the high pressure switch.
    Oct 2009
    pag nag ha high pressure kadalasan barado ung expansion valve ganyan dati ung VTI ko.after palitan at iflushing ok naman na siya.filter dryer lang at expansion valve palagi pinapalitan.saka i paflusing ung mga tubo.at condenser ok na.
Honda esi may amoy kapag nag aaircon at makati sa balat patulong mga boss
