Results 1 to 5 of 5
- Apr 2018
- 9
April 26th, 2018 06:41 PM #1mga bossing sino na pong nakaranas ng gantong senario , lumalamig naman po ung aircon nung una nag hihigh pressured siya so nilinis po nila , then lumamig pero di nawawala ung amoy tyaka makati mga bossing at masakit sa baga,
so ginawa ko pinapalitan ko na ung compressor sabi nung nangagawa is mahina na ang buga ng compressor ko so pinalitan, tapos ung condenser me tama na daw so pinalitan brand new tapos evaporator ung laminated pa brand new wala paden mga kuys . nag hihigh pressured pa din pag nag hi pressured na ayun may maamoy ka tapos makati sa balat .
meron na bang nakaranas sainyo ng ganto kasi nangyayari lang na nag hihigh pressure ang eg ko kapag nag aaircon ang sakit sa bulsa ng palit lahat ng pyesa di naman tinatamaan.
April 26th, 2018 07:01 PM #2
Baka refrigerant leak. That is dangerous.
Refrigerant Poisoning: Symptoms, Treatments & Prevention
- Apr 2018
- 9
April 26th, 2018 07:20 PM #3
April 27th, 2018 12:16 AM #4
It could be that somewhere along the line before the evaporator is the leak. From what I've observed, they do leak test from connections only. That is, the connections from both ends of your evaporator when they replaced it. You can ask them to evacuate the refrigerant and do another leak test. This time, ask them to use a chemical (I can't remember the name) that will be pumped in the system. The leak should be visible with UV light.
If something went wrong with your compressor before, it could have caused clogging the expansion valve which can trigger the high pressure switch.
- Oct 2009
- 2,271
April 27th, 2018 01:34 PM #5pag nag ha high pressure kadalasan barado ung expansion valve ganyan dati ung VTI ko.after palitan at iflushing ok naman na siya.filter dryer lang at expansion valve palagi pinapalitan.saka i paflusing ung mga tubo.at condenser ok na.
see my pahabol statement above. i mean, i can go on vacation anytime. but my spouse has her...
Traffic!
